well at least you'll be able to hear Ted when they cut to him in pit lane
New V6 engines:
1 Pro
257 Cons
:P
But seriously...... they just don't have the that wail that the V8s had. Hopefully they sound better in real life
+1 for wanting Maldonado to leave Williams. They arent going to get any more sponsership by having a driver who is hopeless. They need a talented driver to impress the sponsers and bring more money to the team. Bottas was absoloutly outshining Maldonado at the start of the year. Not sure what happened there
I can't stand the V8 engines they currently have. Well.. not quite.. I'll tolerate them but they don't do much for me.
The V10's on the other hand.. they gave me an eargasm. Never saw a race with V12's but I would probably cream myself.
Turbo + wastegate should sound good.
Correct, on next years engines there are two Motor/Generator Units (MGU). These MGU's are the primary KERS now called MGU-K, and the secondary ERS called MGU-H, the MGU-H is designed to recover lost energy from the exhaust heat (hence the -H in the name) by driving a generator unit connected to the turbine shaft. Depending on how much energy is recovered from the exhaust heat, the turbo's airflow will be modulated in accordance to the engines requirements, this motor will also be used to drive the turbine at low exhaust gas velocities, thereby removing any inherent throttle lag with the system.
  • Like 1
The grandson of Australian motorsport great Sir Jack Brabham has secured himself a drive in the support category for the IndyCar championship in the United States.
Matthew Brabham was confirmed on Sunday as the pilot of the Andretti Autosport entry for next year's Indy Lights 2014, following his dominant win in this year's Pro Mazda Championship.
Brabham earned the right to move up to the Indy Lights championship after winning the Pro Mazda title in emphatic style, claiming 13 race wins from 16 starts.
It means the 19-year-old is just one step away from joining compatriots Will Power and Ryan Briscoe in America's premier open-wheel motorsports championship.
Advertisement
"I'm really excited to be moving into Indy Lights next year," Brabham said.
"I remember seeing the Indy Lights cars for the first time in St Petersburg when I was racing USF2000 there last year. I was blown away by how quick they were and how cool they sounded.
"It's going to be a fun year, and I'm very pleased to be on board with Andretti Autosport for a second year."
this is what i cbf writing. :)
this is why I love tech
and it will eventually filter down to us consumers
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
