I am pumped. Dan has been called up to test the RBR at Silverstone. Lets hope he can seal the deal and we see another Aussie in a top seat next year
Joe Saward seems to think its the wrong choice fro RBR and they should be looking at JEV.
Also interesting to see Coughlan has left Wiliams and Pat Symonds has signed up. SO many changes cant be good for Williams but hopefully Symonds can convince Maldanado to bin it and get Bottas in a good spot after a safety car
It should be pointed out that Joe Saward is a pharken idiot who's opinion is not worth a cold dog turd.
Looks the goods, wonder how much cheaper Kimi he would be....
SMACK BANG ON THE MONEY THERE. Our boy is looking real good as the chins replacement. However, will come down to dollar amounts vs experience
I bought the G27 the day that F1 2010 was released for PC, played it about 4hrs that Friday night then put it back in the box never to be touched again. Was planning on selling it but may need to hold out until F1 2013 Classic Edition is released...
And Sainz Jnr was only 0.044s slower than Dan in the STR on his first ever drive in an F1 car. That's faster than Dan was in his first drive of the RBR, with 2yrs F1 experience under his belt...
Edited by hrd-hr30
Track condition, temps etc will have something to do with it. Hard to say how much however. But seen as they were on different days I don't know if it will be quite as bad as it looks on paper.
Must be hard driving 2 different cars in the same day. Wasn't entirely shocked that he was slower in the Red Bull considering it wouldnt be set up for him or even designed with him in mind. So yeah hard to really say, hopefully its not a cross against Dan's name
World Champions stand. Was there this year, up the back this time. Was right in the front row this year which was alright but everyone walked past all the F$&@#$@# time which meant you had to move your legs all the time
Just wonder if the dates are locked in now that Melbourne isn't round 1 anymore. I'd like to look into accom soon but cant really do so till the date is set in stone
Pretty sure no setup changes were allowed on the car on the day. Not sure what they might have changed overnight....
Werent the established drivers forced to run the new tyres with no setup changes...vs the rookies allowed to test development parts and change setups? Many variables for the relative pace....but all the same Sainz was impressive first time out
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
