If they were the only two other people in the room I think I would prefer to sit back and have nothing to do with them
Lol.... pretty much
Sucks being out at work while races are on. Only just got to watch it this morning, 2 years in a row I've missed watching my favourite race of the year :(
Sad to see Kimi end his awesome points/race finish streak
Getting sick of Vettel running away with every race now.
Martin Whitmarsh believes Kimi Raikkonen is determined to move away from Lotus and also revealed McLaren held discussions with the Finn last year.
Asked if they had ever considered re-signing the Finn, Whitmarsh told the official F1 website: "Yes, we have. Kimi has always been great and I am a big fan of him. There is a lot of speculation out there at the moment, so let's see what happens.
He added: "I probably shouldn't be, but I'm completely open - last year we had talks with him, but for various reasons it didn't happen. This year we've had no talks - yet."
As for where Raikkonen will end up, Whitmarsh said: "Obviously Kimi is determined to go somewhere else and I sense that he will not succeed in that goal, so let's see how he gets on there."
http://www.planetf1.com/driver/18227/8892110/McLaren-talked-to-Kimi-over-2013-seat
purely for my own entertainment, i sort of want him at the fuzz just to watch fernando's mind meltdown
everybody is too comfortable at the moment, let gets some of these guys freaking out a little
You have to like their chances of being one of the 3 strongest teams next year. They have had a tech re-shuffle which should have cleared the decks which along with a poor 2013 will allow a good run at the 2014 car
Plus, I doubt Perez or Button are getting the most out of the 2013 car. History shows Perez cant qualify and nor can Button and 4 weekends out of 5 Button can't get everything out of the car...so granted car isnt great but doubt its as bad as the results suggest
That seems odd..... Hasnt Martin Brundle driven one of the Red Bull cars (not sure which year it was from) and I'm pretty sure he would be a bit 'wider' then Dan. The new car cant be THAT much wider then the older cars
The amount all F1 drivers train I wouldnt think that this would be an issue for Dan...
I think if Webber can fit, Dan should be able to fit. I'm aware its going to be a new car that Mark wont really have anything to do with but looking at the two of them, they dont look that different at all in build. I would say Dan is probably smaller if anything
More and more chatter about the kimi move back to the red team
Maaaan, I can't wait to see the old hysterical victimised spaniard back!
I hope after this year when vettel steps all over his dreams, he sticks it to him again for the 5th year in a row. Can ferrari absorb all that is hurricane fernando?!
Only 2014 can tell!! What a great silly season
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
