Vettel is cleanng up his new rubber latex bondage suit and rubbing his hands and peanut sack and loving the fact he has another aussie to ram his 3inch knob into.
Big mistake for Dan. He is now the new official Barrichello.
Would much rather have seen Kimi there as he would have floored the little top bloke vetstool.
Off to Japan F1 next month. Will be boring as hell but I only go for the beer and Japanese candy.
So many writing off Dan before he has even lined up for a single practice session in the same car on the same weekend. I am not convinced it has been done purely because the expectation is that he will be a lap dog.
I think he has real pace...if RBR wanted to make their lives easy they would have canned Webber 2 years ago and put in any number of drivers like Di Resta, Hulkm an STR Jr etc. Webber has tried to give as good as he has taken and the team has hardly been harmonious whilst he and Seb have been battling.
I think its too presumptious to think that RBR want a lap dog and No.2 by definition. If Dan cant keep pace then he will be a No. 2 by default not by design. The other big reason why I think they need to put someone who will put it up Vettel is that by the end of his cotnract he will have been there 7 years! I think he will be looking for a change/challenge (provided the other team is competitive like mercedes or Ferrari) if he gets bored at RBR. And a young guy beating him will keep him interested and motivated.
Kimi, based on his behaviour at Ferrari doesnt always stay all that motivated when things are not going to plan
Depends on how much Tool can dictate terms to RBR doesnt it? Hoping Dan is like Webber in respect to not putting up with sh!t from anyone. Hoping he is not like him in terms of being able to get a car off the line.
Fingers crossed it goes well. Because other than some young bloke by the name of Brabham I cant think of where the next Orstraylian GP driver would come from.
it looks like he's focusing on indy.
for now anyway.
I'm not writing Dan off before he's started, but the facts are these:
Dan is not outscoring his current team mate. Not last year, and again this year. I don't think the three, soon to be four time WDC will be terribly worried in terms of the championship.
Dan appears to be a good qualifier. Problem is, Webber was also regarded as a very good qualifier... I wouldn't rate Dan as better than Webber in that regard. Maybe he'll prove that wrong, but I don't think so.
Webber is also a very good racer. I would definitely rate Webber's racecraft and race pace as significantly better than Dan's.
Dan does have one thing on his side, and that's the potential to improve.
Edited by hrd-hr30
Roy I'm knocking Dans ability but with Dietrich and Helmet head at the reigns and a German World Champ then Dan needs to learn how to say woof !.
Hope it's a different scenario but after 30 plus years of following F1 just looks the same old same old , just a different lap dog.
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
