Interesting to compare Dan and Jev?
But the real point that I am stoked about is Romain has been in teh points the last 7 races ,inc three 3rds. The Singapore DNF is the only hiccup and he was in a strongh position when that happened. He is finishing the year nicely!
Its interesting because I have to reach for the excuse jar for Dan. I had through that the stats would have added up rather favourably for Dan given his form post Silverstone.
Doesnt mean anything much Roy. If you drag the smoking wreck of a busted pos of a car home in 20th instead of retiring it you can shift the numbers by one in just one race. The are 3 vs 5 DNFs off the back of 13 races. So JEV has only 8 finishes, Disco 10. A 20th for JEV would make his number worse than Dan's. Also it is hard to "out race" your team mate when they have retired.
Singapore, for example, was a bad race for Ricciardo. He stuck it in the wall from 15th position or thereabouts which helped his numbers.
Edited by djr81
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
