Haha. I lost my shit at Webber binning it on the podium, also Alonso and to a lesser extent Vettel gave him a decent champagne bukkake as well lol.
I'm going to miss Webber and the V8's next year. I dont believe that the V6 turbos will give the same aural satisfaction, but, I still can't wait until next season. Only 4 months to go now :D
Edited by chus13
The podium was funny. And what a great moment to see Mark with his helmet off. I am hooked, going ot be hinting for the limited edition pic of that shot!.
Cant wait to see him at Le Mans nest year. Austrian GP, Lemans and Goodwood means ery fe track days for me over the next 6 months
And, again, whether Dan has improved his race pace or Jev lost the plot.
what do you mean "and again.."? Last race JEV caught Dan. Swings and roundabouts...
It's like saying "And again, whether Rosberg improved his race pace or Hamilton lost the plot".
Hard to draw meaningful conclusions from one mixed up race where they had no dry setup time in practice - Button got 4th just to prove how mixed up it all was here.
Edited by hrd-hr30
Jones is the pick IMO due to the sun being behind your back and the ability to see the run into turn 1. Brabham has the sun in your eyes and you only see the cars when they arrive at turn 1.
thanks!
this is what I needed to know. :)
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
