Bruno Senna has walked away from Formula One, signing a deal to race for Aston Martin in this year's World Endurance Championship.
Senna will share the #99 with Fred Makoweicki contesting the full Championship while Rob Bell will join them for the Le Mans 24 Hours and the Spa 6 Hours.
http://www.planetf1....-farewell-to-F1
Marussia have confirmed Luiz Razia as their second driver for 2013.
http://www.planetf1....a-confirm-Razia
Day twoTimes
01. Romain Grosjean Lotus 1m18.218 95 laps
02. Paul di Resta Force India 1m19.003 + 0.785 95 laps
03. Daniel Ricciardo Toro Rosso 1m19.134 + 0.916 83 laps
04. Mark Webber Red Bull 1m19.338 + 1.120 101 laps
05. Nico Hulkenberg Sauber 1m19.502 + 1.284 99 laps
06. Lewis Hamilton Mercedes 1m19.519 + 1.301 15 laps
07. Sergio Perez McLaren 1m19.572 + 1.354 81 laps
08. Felipe Massa Ferrari 1m19.914 + 1.696 78 laps
09. Pastor Maldonado Williams 1m20.693 + 2.475 71 laps
10. James Rossiter Force India 1m21.273 + 3.055 19 laps
11. Giedo van der Garde Caterham 1m21.311 + 3.093 88 laps
12. Luiz Razia Marussia 1m23.537 + 5.319 31 laps
http://www.planetf1....-Way-On-Day-Two
http://www.planetf1....ictures#photo=2
good job mang.
problem solved?
btw.
Lewis Hamilton has billed the brake failure that caused his Jerez crash on Wednesday as "all part of testing."
Hamilton's first official day in his Mercedes W04 came to a premature end when, just after 15 laps, he suffered a rear brake pressure problem.
Although using the front brakes to slow the car, the 28-year-old was not able to prevent a crash, hitting the tyre barrier at the Dry Sack hairpin nose first.
Mercedes later revealed that the problem was caused by a hydraulic brake line connecting to the right-rear calliper.
http://www.planetf1.com/driver/18227/8476009/Hamilton-Better-now-than-later
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
