http://www.planetf1.com/photo-gallery/8509639/A-Look-At-Williams-FW35#photo=10
Williams and Caterham may have to drop the controversial vanes that sit in the 'Coanda channel' of their 2013 Formula 1 cars after being advised that the FIA considers them to be illegal.
The new Williams FW35 features a two-part vane behind the exhaust, mounted at the top of the U-shaped channel into which the exhaust pipes exit, while Caterham has a similar one-piece part placed a little lower.
Technical director Mike Coughlan was adamant that the part is legal when asked about it in the wake of the car being unveiled on Tuesday morning.
He believes the fact that the vane is in two parts makes it permissible, whereas he sees the Caterham design as illegal because it is a single piece and fully encloses the Coanda channel.
But the Williams team has confirmed that the FIA approached it on Tuesday morning to express its view that the design, along with that of Caterham, is illegal.
The FIA insists that an exhaust's primary purpose must not be to affect the aerodynamic performance of the car, a stipulation governed by a combination of the technical regulations and private technical directives issued to the teams.
In order to ensure this is not happening, it deems that the sides of the Coanda channels are not allowed to converge in any way, meaning that they must be vertical or slope outwards.
Exhaust gases are allowed to have an incidental aerodynamic effect, but what Williams and Caterham have attempted is understood to be seen as overstepping the mark.
Despite the FIA's concerns, its current position is only advisory and both teams can continue to run their designs during testing, which is unregulated beyond safety standards.
Should they continue to run them once the season starts, the FIA is able to refer the matter to race stewards for consideration.
When contacted about the situation, a spokesperson told AUTOSPORT: "The team spoke with the FIA this morning (they approached us), which is when they gave us their view.
"The team are now seeking further clarification on this and a decision as to whether this design will be carried forward will be made before the first race."
http://www.autosport.com/news/report.php/id/105623
Times
1 Sergio Perez McLaren 1m21.848s 97 Soft
2 Sebastian Vettel Red Bull 1m22.197s +0.349 84 Soft
3 Kimi Raikkonen Lotus 1m22.697s +0.849 43 Medium
4 Lewis Hamilton Mercedes 1m22.726s +0.878 121 Hard
5 Fernando Alonso Ferrari 1m23.247s +1.399 76 Medium
6 Valtteri Bottas Williams 1m23.561s +1.713 98 Soft
7 Daniel Ricciardo Toro Rosso 1m23.718s +1.870 70 Medium
8 Paul di Resta Force India 1m23.971s +2.123 62 Medium
9 Nico Hulkenberg Sauber 1m24.205s +2.357 88 Medium
10 Max Chilton Marussia 1m25.115s +3.267 67 Soft
11 Charles Pic Caterham 1m26.243s +4.395 102 Medium
http://www.planetf1.com/driver/18227/8512691/Perez-hits-the-front-in-Barcelona
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
