Thanks rb26zed. Thats the info I am after. Going to start saving now.
You recon 8 years old is perfect age or could you have taken him earlier?
P.S. thanks BenM checking out that site now. Looks good!
Dezz- general admin seats normally ok?
Hahaha seats.... GA there are no seats. You can wander around and enjoy the atmosphere but don't expect a spot where you can watch the race and actually know what's going on (near a big screen etc) unless you get there at 6am and sprint :P
Most stands are opposite a big screen which keeps you up to date - although some are a bit hard to hear (Clarke stand!).
However, you can buy headphone things that double as a protector of your ear drums and also have the commentary. They are around $50.
These things:
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
