That opening scene from Enemy at the gates has put me off Russian Ferries.
Have you seen where it is?
You'll get a free donkey with every Ferrari shirt purchased.
But it would be epic. Have to do a ferry trip to Odessa afterwards.
Monza is fun but shit viewing and run by Italians so ... ummm. Spa is again not great for viewing as its a big open track though seats on the entry to Pouhon are cool. Hungary is way good for stands where you see plenty of track. Personally i would go to Hungary, German and Belgian GPs...Monza may keep the Mrs happy but without kanga tv this year i think any live gp will be a challenge for understanding the race
Thanks guys, have got me thinking now. German gp's pretty much a lock in because I'm here already, Hungary looking mighty tempting too as it lines up perfectly with the end of my contract. British & Monaco are also being considered, could be a great year of watching motorsport! Also keen to try & get across for goodwood but need to check my dates.
Have to be back in aus for August so unfortunately Belgian Gp is out which is unlucky as had free accom with a mate sorted.
thanks again for the suggestions guys, if anyone can recommend specific stands fire away, I'm all ears
Jenson Button has become a director of the Grand Prix Drivers' Association (GPDA), AUTOSPORT can reveal, replacing Felipe Massa.
http://www.autosport.com/news/report.php/id/106247
The Mercedes Formula 1 team has confirmed that Nick Fry will step down from his current role as CEO at the start of next month.
As revealed by AUTOSPORT earlier on Friday, Toto Wolff will increase his responsibilities within the team while Fry retains a consultancy role for Mercedes.
http://www.autosport.com/news/report.php/id/106251
Shoot me your email addy. Happy to tell you where I went wrong with some of my trips which may save you making the same mistakes :)
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
