I received the following information from our CAMS Development Officer.
The CAMS Come and Try Day 2013 is Near!
Individuals can participate in the Driving aspects of the day AND ALSO Officiating to experiencing firsthand what it is like to be an official!
Entry is ONLY $30!
*This day is only for individuals who haven’t held a CAMS competition licence before.
CAMS Come and Try Day 2013 Registrations.pdf CAMS Come and try Day 2013 Supp Regs.pdf post-16200-0-40242000-1353895130_thumb.jpg
https://www.sau.com.au/forums/topic/414433-cams-come-and-try-day-2012-19th-jan/
  • Replies 71
I sent an email and got this in reply,
The CAMS Come and Try Day 2013 will consist of the following events:
- 1 hour of Supersprint which includes cars being sent out at different intervals, you will be competing against the clock and not anyone else. There will be a coach with you inside the car to teach you how to use the whole race track also. You may be able to get around 5-10 laps on the new South Circuit at Sydney Motor Sport Park
- 1hour on Motorkhana which includes a circuit being developed by Thornleigh Car Club who will be running that section and it’s a way to test your control over a car on wet and dry surfaces through some tough turns around cones and returning to the starting position, this is also a time trial based event. So you may also be able to get a few turns on this.
Keen to try the South Circuit but doesn't sound like there will be much track time
Pffft, for $30 it's way beyond a bargain! Do it, the things you learn when you take up an opportunity like this will FAR outweigh the cost.
If you really expect more track time when you're paying such a low entry fee, then you have no idea on what it takes to run an event like this. We, as a club, would love to run an official SAU-NSW event there, but we can't afford it.
:D
Exactly Nick, that's why I'm booked in for it. $30 to get on the track, with a coach is winning.
It's a come and try day, not a full on track day because they are trying to encourage people to Motorsport, not running it for those already involved.
:D
Yeah that's true but more track time, more to learn :D
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
