Glad to hear was such a good day for everyone. Now that you've had a taste, time to get out at some of our events for a proper full day of runs and fun.
How many skidpan runs/courses did you get on this day? Our Texi's we get six courses and three runs on each for about the same price (for members)!
  • Replies 71
The idea was everyone got 4 runs through the motorkhana, though some probably got more. Any chance SAU could do a motorkhana on the wet pan? I feel like dry pan/texi would be much more punishing to the car (plus I'd lose cheater car advantage).
My best time was 43 on the skid pad, couldn't seem to get any traction and kept doing donuts. I tried very hard to get a good time, promise hahaha.. even the official said I got the worse time haha
Edited by johnnilicte
yah been to plenty of TEXI days in my 33 so the highlight definately south circuit pushing the Re001 potenzas to their limit was awesome.
Will hopefully have my 32 ready for wakefield this year ;)
hi all,
i was also in the green group. i was in the black wrx sedan.
had a ball, really surprised at the level of grip in the wrx. except also came unstuck through the left hander coming onto the front/side straight. its a bit tailly off throttle, carried too much speed in and she stepped out. havent got the awd drift thing sorted yet.
managed quite a few good times on the skid pan. first without hand brake was a 35.03, followed by a 30.55 with handbrake. 3rd run was a 29.03 and finished with a 28.63. absolutely spanked the car, had a ball.
+1 for wet skid pan event.
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
