Hi all,
Please see my for sale list below and feel free to send me a message on here if you are interested, I'll check them daily; leave your number too and I will call you back. I'm going overseas in 10 days, so what isn't within that time frame will probably have to wait a few weeks till i get back.
Item 1: R34GTR PowerFC in good condition, only in car for about 2000k's - comes with hand controller (it's the new style LED screen) AND FC boost control kit! - it's missing the two gold in/out nipples for the boost hoses to go into. $750
Item 2: R34GTR HKS Hi-power Silent exhaust, 3000k old. no dings, great condition. $500 no gaskets
Item 3: Rb26dett dump pipes, I have two sets, Stock BNR34 and Xforce split dumps. Xforce are brand new, stocko's are used. $250 either pair.
Item 4: BNR34 JJR intercooler (100mm core) travelled 15k, very good cond, no dings to tubes. $200
Item 5: Unknown brand TE37 copies (Rota maybe), Powdercoated gloss black, 19x9.5 (Two wheels only), no damage, no gutter rash. have achilles ATR's (19/275/30) on them with a good amount of tread left. Don't know offset off the top of my head, but they fit the 34 well. $400
Item postage is possible if the sale is soon, otherwise need local pickup
thanks,
Pics will be added below tonight.
pic's attached, also have a stock 34gtr intercooler, $100 pickup, with the pipes too.
Still missing pic of JJR intercooler. will get that up when I can
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
