Hi John
I've meet you few times at UAS, John told me about this thread, will be good to see how this car progresses, subsribed
I'm a big fan of the blue front bar in the above video... Do you know who makes it?
It is a custom bar that was made by Phil Coles ( who drove the combined touring car ) and the guys at BSM for this car when it was still racing in IPRA
Marko... It's called a safety factor. The goal was to run about 400rwkw @ 20psi as a run in tune.
The car is getting completely rewired mid - late January and then I want to get it out for some practice runs...
your saftey factor results in 440kw...... F@$k'n AWESOME
Having gone through another few projects in the past and "trying" to keep control of the costs, my aim was to try and get about 400rwkw at 20psi as we think this should be "safe"... 440rwkw at about 23 psi is pretty good but I do not want to push the motor as it is a fresh rebuild.
I'll get it out for some private practice and get a few kms then we might look at whatever the restrictions are and then push a bit harder. The turbo should be good for around 900hp at the flywheel?
  • Like 1
Tune on BP98?
Its running Caltex e-flex E85 fuel but a lot of people I talk to are running the United E85 from Rozelle in Sydney... not sure if this is a better fuel? Anyone?
ATM I believe the tune is quite conservative running on the richer side and not too much timing...
Thanks for the thread John am enjoying it.
Great work
It will hopefully get more interesting once I get it out for a run.
Here is the plan from here:
1. Get the car rewired and recheck the tune at UAS.
2. Take the car out for some practice
3. Sort out suspension need front & rear adjustable control arms, tie rods etc... do roll centres and try and fit 295s under the guards. (The car ran 265s alround when it ran the 1:35 at 2010 time attack)
4. Get the car down to Tune house on the 4WD dyno for a higher power tune and to check 4WD operation
5. Try and make it to Nissan/Datsun Nationals
6. Aero... Replace rear wing and setup proper under tray
7. Practice, practice practice
8. Get to World Time Attack in October!
Oh... and try to lose 15kgs in between...
You should have no problem getting the 295s under the guards. I'm running 305x680x18 Pirelli slicks no problem.
What 4wd controller are you using?
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
