Yeah ... money, money, money ...all going into that big black hole!!
But I'm not giving up, it will be sorted out... I'm in my mid 40s and if I do not get this project finished and the car running to its potential then I might just throw in the towel. :(
Latest update...
- The Holinger will not be delivered until mid - late July. Has anyone got a spare gearbox to loan me for a couple track days? I promise (fingers crossed) I won't break it.
- Electric Power Steering pump installed and will get wired up into the Motec PDM.
- I'm replacing the Odyssey with a Lithium battery (its due to die soon)
- I'm looking at installing the adjustable Ikeya lower control arms
It's been close to 18 months and I still have not had a decent drive in the car yet...
I'm not sure if I am going to put in an entry form for Superlap this year ...
Send me a Pm if your interested. It took a bit to get right and Im a sparky. Couldnt find much info off the net. But i think ive got it right now. Taken the car out now a few weekends now and no probs. Good mod in my opinion.
  • 3 weeks later...
Update:
- Astra Power steering pump installed by UAS using standard astra fuse/relay but is not setup with PDM yet. Will be hooked up properly in the next week or two by my motec guy.
- Holinger sent an email... box should be ready late June/early July... fingers crossed it turns up sooner rather than later.
- Rear lower control arms fitted by UAS, waiting for front Ikeya arms to arrive.
- Application to WTAC PRO-AM class was successful.
Now I need to get serious with getting myself ready for the challenge... need to lose another 10 kgs, sort out the right knee and get in some sort of shape (other than round).
It's gonna be fun!
  • 1 month later...
Received confirmation that the holinger should be delivered this week... hopefully it will be installed and be drivable again next week.
Now I need to get the wheel alignment sorted to a starting point, finish off some wiring and then get the car down to Tunehouse to check the tune and give it a tweak then off to get a feel for it around Sydney Motorsport Park...
Should be interesting!!
  • 4 weeks later...
Thought you guys might be interested in the latest on the Tunehouse R32 GTR. We recently have been doing final mechanical work, check ups and dyno tuning.
We held a photo shoot last week, the photos have been posted up on WorldTimeAttack.com with specs of the car:
http://www.worldtimeattack.com/index.php/the-open-class-skyline-army-gets-a-new-recruit-with-the-tunehouse-r32-gtr/
The machine hit the hub dyno on Saturday to be tuned by Tunehouse owner Jim. Comfortably and efficiently we made 500 AWKW @ 16 PSI, looking to go up to 25 PSI in the future.
With the tune done, the keys (so to speak) were handed over to John Boston last Sunday for a shakedown and test lap. You can check out his in cabin camera footage here:
https://www.facebook.com/photo.php?v=10201592045342138
And another of it moving out of the pits:
https://www.facebook.com/photo.php?v=10201588104603622
There are some minor enhancements to with fuel and oil pressure, but working out the kinks is to be expected of course.
The car is being entered into the open class @ WTAC this year and we are keen to see what it can do.
We'll keep you guys posted!
Tunehouse
It's certainly making the numbers, hopefully you can get it set up to put power to the ground.
Let's have a closer look at the aero please.
More detail around the splitter/undertray, and the rear wing + diffuser section would be great.
Sorry about the footage guys, the videos are hosted on somebody's personal account.
The aero and diffuser work is all custom, unfortunately there's not much more I can tell you than that.
Tunehouse
Boost level is consistent, our hub dyno picks up every little twitch in the output.
I know how a hub dyno works, you should be making peak torque at around 5000-5500rpm not 7500rpm. Something is causing you to lose a lot of mid range power?
PS. How do the RB20 Nics covers go with blow bye?
Edited by SimonR32
Any chance you might post up some pictures? That was the detail I was referring to, wanted a look if possible.
    • Yes there is a front and back insertion point on each side, each point is tubed with supports into the car and tied to the cage/ floor mount point
    • Is the jack stand system tied into the cage somehow? Upgrades look goooood 😍
    • Big updates, tons of work and $$$
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
