Yeah ... money, money, money ...all going into that big black hole!!
But I'm not giving up, it will be sorted out... I'm in my mid 40s and if I do not get this project finished and the car running to its potential then I might just throw in the towel. :(
Latest update...
- The Holinger will not be delivered until mid - late July. Has anyone got a spare gearbox to loan me for a couple track days? I promise (fingers crossed) I won't break it.
- Electric Power Steering pump installed and will get wired up into the Motec PDM.
- I'm replacing the Odyssey with a Lithium battery (its due to die soon)
- I'm looking at installing the adjustable Ikeya lower control arms
It's been close to 18 months and I still have not had a decent drive in the car yet...
I'm not sure if I am going to put in an entry form for Superlap this year ...
Send me a Pm if your interested. It took a bit to get right and Im a sparky. Couldnt find much info off the net. But i think ive got it right now. Taken the car out now a few weekends now and no probs. Good mod in my opinion.
  • 3 weeks later...
Update:
- Astra Power steering pump installed by UAS using standard astra fuse/relay but is not setup with PDM yet. Will be hooked up properly in the next week or two by my motec guy.
- Holinger sent an email... box should be ready late June/early July... fingers crossed it turns up sooner rather than later.
- Rear lower control arms fitted by UAS, waiting for front Ikeya arms to arrive.
- Application to WTAC PRO-AM class was successful.
Now I need to get serious with getting myself ready for the challenge... need to lose another 10 kgs, sort out the right knee and get in some sort of shape (other than round).
It's gonna be fun!
  • 1 month later...
Received confirmation that the holinger should be delivered this week... hopefully it will be installed and be drivable again next week.
Now I need to get the wheel alignment sorted to a starting point, finish off some wiring and then get the car down to Tunehouse to check the tune and give it a tweak then off to get a feel for it around Sydney Motorsport Park...
Should be interesting!!
  • 4 weeks later...
Thought you guys might be interested in the latest on the Tunehouse R32 GTR. We recently have been doing final mechanical work, check ups and dyno tuning.
We held a photo shoot last week, the photos have been posted up on WorldTimeAttack.com with specs of the car:
http://www.worldtimeattack.com/index.php/the-open-class-skyline-army-gets-a-new-recruit-with-the-tunehouse-r32-gtr/
The machine hit the hub dyno on Saturday to be tuned by Tunehouse owner Jim. Comfortably and efficiently we made 500 AWKW @ 16 PSI, looking to go up to 25 PSI in the future.
With the tune done, the keys (so to speak) were handed over to John Boston last Sunday for a shakedown and test lap. You can check out his in cabin camera footage here:
https://www.facebook.com/photo.php?v=10201592045342138
And another of it moving out of the pits:
https://www.facebook.com/photo.php?v=10201588104603622
There are some minor enhancements to with fuel and oil pressure, but working out the kinks is to be expected of course.
The car is being entered into the open class @ WTAC this year and we are keen to see what it can do.
We'll keep you guys posted!
Tunehouse
It's certainly making the numbers, hopefully you can get it set up to put power to the ground.
Let's have a closer look at the aero please.
More detail around the splitter/undertray, and the rear wing + diffuser section would be great.
Sorry about the footage guys, the videos are hosted on somebody's personal account.
The aero and diffuser work is all custom, unfortunately there's not much more I can tell you than that.
Tunehouse
Boost level is consistent, our hub dyno picks up every little twitch in the output.
I know how a hub dyno works, you should be making peak torque at around 5000-5500rpm not 7500rpm. Something is causing you to lose a lot of mid range power?
PS. How do the RB20 Nics covers go with blow bye?
Edited by SimonR32
Any chance you might post up some pictures? That was the detail I was referring to, wanted a look if possible.
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
