Like I said above, the 6768 had no problems making power, we did not push it ... barely touching 18psi for the 500 awkw. Making the power down low is where we need it then winding up the boost to make the top end is the plan !!
500 awkw is enough to play with (to start with)... I've done about 8 laps in the car so far... 5 at Phillip Is with no power steering and maybe 3 around SMP North Circuit with the Holinger with oil pressure warning alerts, which ended up being a case of trimming down the alert threshold at low rpms.
Should be fun once its sorted!! Still got to get used to the sequential but no problems slaming through the gears with the foot flat to the floor down the striaght !! :)
Ok guys, I need help finding a rear wing... Voltex can't make me one in time, the local APR distributor has not got back to me, He said he was getting a few dual pane Nemo style ones in (designed by the man!!) and I asked that I get my name put on one...
Anyone have any suggestions on where I can get one quickly or know someone that has one lying around ??
It needs to be 1695mm + 200mm long (including end plates) !!
Michaels email is [email protected]
http://www.kognitiondesign.com
Or lightning composites are in aus http://www.lightningcomposites.com.au/
As are topstage.
Edited by DCIEVE
Thanks... Freddy seems pretty good. See how I go. I like his front diffuser too.
Need to find someone to make the wing mounts. Thinking of going around the back and under the car ala GT3 style??
New fuel system was fired up today.
New Turbo should be delivered by end of next week.
Will need to wait for Jim (Tunehouse) to get back before it gets tuned. Gives me two weeks to get everything else done.
Still need to choose wing, get it and sort out mounting.
Front bar needs to be remounted and secured better as it broke the side mounting bolts and was dragging on the ground at speed.
Ive been away, back tommorrow... Time to pull the finger out!!
Do you want it in dry carbon or fiberglass John?
I have a custom widebody fenders that will clear 315/xx/18 11-12 inch easily. I have a spare fiberglass front fenders, Topstage has the moulds for both front and rear fenders atm. If you are keen then you should talk to Freddy but I think you are leaving it too late.
The rear will involve cutting your whole fender off and replace it with a dry carbon piece. The front is "almost" bolt on. I made some modification to the firewall for aerodynamic reason and the fender is shaped for it...if you struggle for time and dont have time to modify the firewall, then cut off the inner "flare" of the fender and bolt it straight on to your car..it should still help with the aerodynamic.....that's if you sweet talk Freddy into working 24 hours.
Best bet is to flare the rear and look for another wide front fender. I searched everywhere before and could not find a dry carbon one or even a wet carbon with aerodynamic on it for the r32 gtr...hence I had to design my own. I even bought one from EA and it did not fit. I am happy help you out if you are stuck and let you have my fiberglass one, if you need it, with the right offer..... I really don't know how much it worth...but it costed me a bomb and lots of hours.
Check my build thread if you want some pictures.
Talk to Freddy John. Between Freddy and I, we have most of the R32 GTR body moulds. I don't really know how much to charge you for using the mould...just ask Freddy for a fair price....happy to help another SAU member.
Good luck John and it will be good to catch up on the day.
Thanks for the offer on the front guards just pm me what you want for the fibreglass front guards and send me some current pics of what they currently look like... I will let you know if I am interested.
I was hoping for a bolt up straight fit solution to the front guards and Im anticipating the rear is not going to be that straight forward.
Im not looking for a long term solution as the car will be going on a diet after WTAC and Im going to have a proper look at the aero.
My priority is to get the mechanical, electrical and chassis sorted and get some seat time... Everything has to work and be reliable hence the looks are not so important for my first WTAC...
The FG were prepared and primed for the mould. They have been wrapped straight after moulding and in storage since. I won't have time to take it out just to take pictures but it should look like this
These look awesome! How much wider are they, and are these actual pics of the guards to fit R32 GTR?
Do they have more clearance for extra lowered cars as in John's car now has the option to go lower as the roll centres are raised?
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
