Hey Guys,
Need some help.
Last weekend me and a mate did a bosch 040 install in my skyline which went to plan.
Early this week i noticed a puddle under my car after parking it. I also smelt a heavy fuel smell
Opened the boot and undid the nuts to the pressurised lid above the fuel tank.
See Picture
We accidently put a different hose clamp which was a little too tight on the bottom right hose. It now sprays a small amount of fuel when priming and accelerating.
I really dont want to drive it and die ;P so would like to replace the hose at home.
Can you please tell me;
Where does the bottom right hose from the fuel cap go?
How do i get to the end of it to replace the entire thing?
Cheers,
Ryan
https://www.sau.com.au/forums/topic/414469-fuel-line-hole-help-plz/
hey mate i replaced that hose just recently. it's roughly half a meter long if that and runs underneath the car and clamps to a steel fuel line. ideally you would remove the whole fuel tank to replace these hoses but it is possible without removing the tank. just a bit fiddly trying to feed the new hose down under the car. make sure you get 'efi fuel' hose not a coolant or vaccum hose. i have seen this done before lol
Thats great thanks mate!!
How do i access it without taking tank out. from underneath the car?
Where can i get EFI hose?
Su
Got the hose. How do i get to the other end of the stock hose? Do i go under the car or take out the back seat?
suggest you run the car up on ramps or put on axle stands and take a look
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
