Hey Guys,
Need some help.
Last weekend me and a mate did a bosch 040 install in my skyline which went to plan.
Early this week i noticed a puddle under my car after parking it. I also smelt a heavy fuel smell
Opened the boot and undid the nuts to the pressurised lid above the fuel tank.
See Picture
We accidently put a different hose clamp which was a little too tight on the bottom right hose. It now sprays a small amount of fuel when priming and accelerating.
I really dont want to drive it and die ;P so would like to replace the hose at home.
Can you please tell me;
Where does the bottom right hose from the fuel cap go?
How do i get to the end of it to replace the entire thing?
Cheers,
Ryan
https://www.sau.com.au/forums/topic/414469-fuel-line-hole-help-plz/
hey mate i replaced that hose just recently. it's roughly half a meter long if that and runs underneath the car and clamps to a steel fuel line. ideally you would remove the whole fuel tank to replace these hoses but it is possible without removing the tank. just a bit fiddly trying to feed the new hose down under the car. make sure you get 'efi fuel' hose not a coolant or vaccum hose. i have seen this done before lol
Thats great thanks mate!!
How do i access it without taking tank out. from underneath the car?
Where can i get EFI hose?
Su
Got the hose. How do i get to the other end of the stock hose? Do i go under the car or take out the back seat?
suggest you run the car up on ramps or put on axle stands and take a look
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
