I have an APEXi Power FC controlling a largely stock GT-R motor, with just the usual filter/exhaust mods.
Can anyone help me to convert the displayed output of the airflow meters (Voltage) as seen on the Power FC controller into either a cfm measurement or a lb/min measurement. The flow meters are standard R32 RB26DETT units.
I want to compare this figure, ie the stock turbo flow in lb's/min to the compressor maps for the larger Garrett GT 25 30's and/or the Nismo N1 turbos.
As an aside does anyone have a compressor map for the stock R32 GT-R turbos?
Also, wanted to buy - Standard R32 Rear speakers & covers.
https://www.sau.com.au/forums/topic/41449-rb26dett-airflow/
I think the compressor is exactly the same as the ones used on the T28 on the S14. That means its the T3 60trim compressor which u can find the map here;
http://www.turbocalculator.com/compressor-...-maps/t3-60.jpg
However the RB26DETT might use a different trim, not sure.
https://www.sau.com.au/forums/topic/41449-rb26dett-airflow/#findComment-850541
