G'day people. I have a brand new Genuine Nissan head gasket to suit an RB25. I believe it will fit DE, DET and NEO motors. Looking for $100 firm plus post
Also should note located in Canberra
https://www.sau.com.au/forums/topic/414529-rb25-head-gasket/
Thursday bump. Price drop $80 plus post. This is a genuine nissan head gasket. Recent ebay search puts this at about 150 delivered from the states. So you could have it tomorrow or you could have it in 2 weeks for more money!!!
  • 7 months later...
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
