Looking at eoi at this stage. Not 100% sure if want to thorw anymore money at this car as ive already spent n ass load.
Blown bottom end (suspected spun bearings) happened the other week at SAU nats.
Spoken to JEM about this the other day, alot of the parts can be re used (potentialy just needs new crank n pistons)
Ok the basics of the car:
ive owned this for the last 5 years, it is always garaged
its only been driven twice a week since January this year. Has done 3300kms this year
Motor was originaly built 19/11/2009
fuel system built 21/7/2010
gearbox built 27/9/2010 by award diff & gear box
tyres and rims January this year
here is some of the basic parts, full detailed list of every part on the car can be provided to serious people
Performance metal craft 9l sump
nitto oil pump
nitto i-beam rods
cp pistons
ati balancer
arp head and main studs
nitto full gasket kit including 1,2mm head gasket
ported and polished head
hks step 2 springs
oversize valves
jun retainers
hks 272 10.25 cams
hks t51r spl non bb turbo
trust stainless manifold heat coated
full 4" custom exhuast
trust 60mm w/gate
100mm intercooler with hks piping
koyo radiator
grex 19 row oil cooler with relocation kit
sard 1000cc injectors
sard fuel rail
1 internal bosch 044 pump
2 external bosch 044 pumps
custom surge tank
all braided lines
weldon adj FRP
OS giken 5 speed gear set with strenghtend input shaft
Nismo super coppermix twin competition clutch
C's short shifter
Tein hr coilovers
whiteline front n rear sway bars
standard strut braces
b pillar brace
hicas lock bar
dba slotted rotors
ferrodo ds2500 pads
hel braided lines
Nismo ztune carbon bonnet
border carbon air ducts
carbon 400r front lip
trust side skirts
abflug carbon rear diffuser
bride replica front seats with matching door trims
heaps of gauges
nismo 320km speedo
custom bolt in half cage
carbon look dash
This package made 422kw @ 21psi on 98
Selling the car as is, no part outs or anything like that
There is no money owing on the car
rego until may 2013
i also heave a heap of spare parts and still have all the rear interior that will come with the car
PM me with your email address for pictures or look in my profile for a couple pics but they are abit old
Looking for $20,000 for everything
new bottom end + e85 will get you around 550+ kw
https://www.sau.com.au/forums/topic/414538-eoi-mnp-r33-gtr/
if i keep it, going 2.8l, already priced up and can be done for 15k or less if you take out things i was planning on that arnt realy needed
so for 35k or less you can have a 550+kw street gtr.
alot better then the stuff thats on car sales atm
paint is near perfect
carbon bonnet is painted mnp but vents have been left carbon
had previously run 10.9@ 129mph before current turbo set up ( can provide video proof)
some spares include standard bonnet
polished plenum
rear seats
all climate control
3 centre gauges
spare gear shift surround
red leather gear & handbrake boots
heaps of other stuff in the box
forgot to mention it runs a power fc djetro n blitz dual sbc boost controller
https://www.sau.com.au/forums/topic/414538-eoi-mnp-r33-gtr/#findComment-6643706
Do you have the auction papers etc from Japan?
What auction grade was the car?
No mate I don't have any of that, I bought it already in Australia
Thanks Dave
https://www.sau.com.au/forums/topic/414538-eoi-mnp-r33-gtr/#findComment-6644199
people please read the posts
NO SWAPS
i didnt write this just for the sake of writing something, i dont care what you have, i dont want it
im after cash sale only! i already have another car
https://www.sau.com.au/forums/topic/414538-eoi-mnp-r33-gtr/#findComment-6648039
all pm's replied
if you dont have close to what im asking then dont pm me with low ball offers. and no 15k is not close
may consider removing carbon bonnet, rear diffuser, front lip, gauges if 20k is too much for you
( these parts alone cost nearly 4.5k)
https://www.sau.com.au/forums/topic/414538-eoi-mnp-r33-gtr/#findComment-6652759
Ok people here is the deal
Im tried of getting different offers from people
so here is the only 2 options
20k for everything exactly how it is
OR
15k minus bonnet (standard will be put back on), no front lip, no rear diffuser, no head lights (u will need to get your own) and no gauges (stock 3 gauges and climate control will be put back in)
these are the only 2 options
https://www.sau.com.au/forums/topic/414538-eoi-mnp-r33-gtr/#findComment-6653119
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
