  • Replies 73
Mine is a White 96 R33 GTR V-Spec. Got it from compliance about 2 months ago now and am loving it. Was stock from compliance, have since added:
18x9.5" BBS LM with 265/35 Yokohama ES100s
Reconditioned APEXi T-max coilovers with king springs (FR 400lbs, R 225lbs)
Cusco Caster rod
Cusco rear camber arm
Whiteline Front camber kit and pineapples
DBA slotted 4000 series rotors FR & R
Came with dual APEXi dual chamber BOVs but will probably remove those in favour of a set of stockies.
Time to liberate some HP!
black 92 r32,trust tdo5  turbos,18 x 9.5 racing harts , here is a pic courtesy of merli
You will give me your wheels (waves hand, Jedi style)
awesome.
white 1992 r32 gtr but seems to have all the specs of the 1994 model (pull type clutch, electronic hicas pump in rear of car instead of hydraulic in engine bay etc
Hey Amaru, what does the pump look like in the engine bay / electronic Hicas pump in the rear? What does mine have?
I've got a White R33 GTR which was stock when I got it. (and basically still is) I've added a set of Nismo Clusters and centre gauges and I've got a Power FC ordered (hopefully I'll have it by Xmas) and a set of TE37's which hopefully I'll get in a few weeks.
as my name implies i can only dream about owning a GTR let alone a gts-t at the moment. i've only been for a drive in one slightly modified gts-t and the grin didn't leave my face for days.........buying my first skyline after months or years of slaving, that expression will be priceless.
I just sold my modded 93 GTST Type M. I lost money big time but I have the goal in sight, a 1989 GTR from Japan. still searching at the moment. have missd out on 3 so far. hope to find one this week.
but then its a damn long wait. I'm driving a 1979 Dato wagon at the moment.
I work damn hard for what I have and just hope that no one ever says you dont deserve it.
Have you ever had someone say to you or heard them say you don't deserve that car?
just interested thats all. I have seen some nice cars with wreckless drivers and i have thought that.
cheer
mark
Midnight Purple 95 Vspec
2530's
HKS FMIC
HKS Dumps
OS Giken Twin Plate
Sard 700cc Injectors
PFC + HC + Boost kit
HKS Cam gears
Full zorst
Z32 afm's
K&N Pods
Nismo Fuel Pump
Nismo Regulator
Cusco Catch Can
18" Impul Hoshino Racing rims
Defi Gauges
big stereo
etc etc.
315kw at all 4 wheels on 1.3bar.
Cheers
Brett
Mines a late model R32 GT-R (June 94 to be precise). White, with nismo sideskirts and nismo lower bootlid lip.
HKS suspension (very tough ride)
3 inch exhaust from cat back
17inch X 9 AVS wheels, Yokohama Grand Prix 255/40
Apexi Air (pod) Filters
Blitz Turbo Timer
Pivot Speed meter
HKS Cam Gears
Chip Torque Chip
Dyno: Max Power 233rwk @ 13psi
Quarter Mile: 12.84 @ 105.66mph
Drive it everyday and loving it!
I got a silver 1994 R32 GTR, its got ..
Tein type flex coil overs
Apexi pod filters
HKS front pipes
Trust cat back
DBA 4000 front brakes
WORK Termist 18x9.5 wheels
Rebuilt Standard turbo's with steel wheels
Apexi Power FC
HKS Cam gears
Cusco oil catch can
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
