  • Replies 73
I am like sooooo one step ahead of you :rofl:
LW.
Actually, I am one step ahead of you :) My car is already here :P
Unfortunately, it has been stuck on the docks for over 2 months. :( Even worse, it's not even in NSW. I hope it hasn't been stripped. Thankfully, my other set of mags didn't get put with that car.
Guest two.06l
Silver 93 r32 gtr import
Engine
· Micks Metalcraft 4” Intercooler
· Dual Blitz blow-off valve
· Top Secret Super radiator, Trust hi psi cap
· External 19 row oil cooler with thermostat
& remote filter (not fitted for D.C.)
· Trust clear timing cover
· Trust timing belt (new tension pulleys)
· HKS vernier cam gears
· Nismo valve stem seals & bronze guides
· Knife edged and ported head
· Tomei 260 degree camshafts
· Tomei 1.2mm head gasket
· Tomei oil restrictor kit
· Tomei sump baffle kit
· N1 oil pump & water pump
· Cryogenic treated, crack tested & linished crank
· Cryogenic treated, crack tested, shot peened,
resized, closed & honed polished conrods
· ARP rod bolts & head studs
· Cryogenic treated Aries forged pistons
with teflon coated shirts
· Total seal gapless rings
· Deburred, honed & crack tested block
· Clevitte 77 main & rod bearings
· HKS 2530turbos with HPC coated
turbine housings
· HKS manifolds, HPC coated
· HKS dump pipes with separate
wastegate HPC coated.
· HKS adjustable waste gate actuators
· Tuned length engine pipes
· HKS dunk megaphone 3” exhaust
· HKS piping kit (turbos to plenum)
· 80mm Z32 airflow meters
· HKS super power flow filters
· Sard 720cc injectors
· Trust fuel rail (twin inlet)
· Sard fuel pressure regulator
· Twin Bosch motor sport fuel pumps
· Performance MetalCraft surge tank
· 500hp Bosch swimmer lift pump (in tank)
· Custom alloy catch tank
· Nismo engine mounts
. Splitfire ignition coils
Suspension and Brakes
· Cusco master cylinder brace
· Cusco front strut brace
· Cusco rear strut brace
· Auto Select A pillar braces
· Endless brake pads
· HKS hyper damper coil overs
· JIC rear upper link arms
· UAS front upper link arms
· Rear subframe bushes
· UAS 330mm front brake rotors (not fitted for D.C.)
Electronics
· Apexi Power FC computer
· Apexi AVC-R boost controller
· Apexi turbo timer
· Carel inlet temp meter
· 300km speedo
· Auto meter 0-35 psi boost guage
Driveline
· Jim Berry modified clutch set-up
· Nismo lightened flywheel
· Exedy super single clutch plate
· Nismo 4800 pound pressure plate
· Rebuilt Nissan GTR gearbox with Cryogenic treated internals
· Nismo gearbox mounts
· Falken Azeni tyres
· 17x8 front & 17x9 rear Super Tourer alloy rims
Owner/Driver:
· Stacey Diemar
Research / Development / Tuning:
· Dirt Garage Crew: Paul, Darren, Luke, Duncan, Peter, Patrick
· DP’S Motorsport
· Croydon Racing Developments
Sponsors:
· Wanted,
Engine
turbine housings
Electronics
· Apexi turbo timer
· 300km speedo
Driveline
Owner/Driver:
· Stacey Diemar
· DP’S Motorsport
Sponsors:
· Wanted,
Nice setup there stacey!
Merli,
Not yet, have not had the car 100% since PAS when it got the 421hp. But now with new twin plate clutch, fixing the knock problems and a new front cv I hope to get down to the plex when racing starts again.. Though I have no illusions to my crappy driving abilities, I'd hope to get into the 11's with that power figure...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
