Are you still able to get this complete kit?
yea kits are still available
Lol thread revive. Btw, did any of you Nengun muppets factor in shipping to Aus??
lol yup everyone can get a better kit cheaper... so they say
then they go to freight it in and get scared and the quality is not as good
  • Like 1
  • 5 years later...
On 11/27/2012 at 9:07 PM, fatz said:
Just looking at the internets and stumbled across my mates down the road and they do a r34 conversion onto a stagea
They are not cheap but if anyone wants one and is feeling rich speak up
Australian made stuff and the quality is very good
I buy a fair bit of stuff (yes I am the only wanker with a hr31 in dry carbon) of these guys so I get a discount
The complete kit in parts costs(rrp);
-Guards $ 550/pr
-Bar reo $ 650 (allows the R34 front bar to mate up to the Stagea Chassis rails)
-Headlight adaptors $ 500/pr (allows R34 Headlights to mate up to the Stagea with a minimum of fuss)
-Bonnet Hybrid $1,550 (R34 GTR top skin with C34 underskin)
-R34 GTR bar $ 700
-Front Lip $ 500
-Splitter/Diffuser $ 950(This is a copy of the genuine R34 GTR lower splitter/undertray)
Total is 5400 or 4450 without the under tray
So knock off 10% and that makes
4860 or 4005 without the under tray
Then all you need is some head light
Anyway it's there if you want it
Drop us a pm if you want a kit
Pete
More info below and shit pics
This kit does not require you to de-gas the air conditioning core.
It does not require replacing the factory radiator support with an R34 one. In the past this is the way they have been done.
The Hybrid bonnet goes straight on to the factory Stagea hinges. It lines up with the rubber stops and bonnet catch. As it is a R34 top skin with a Stagea under-skin, so we call it a "Hybrid hood".
The headlight adaptors are moulded brackets which allow the R34's lights to mount to the Stagea's radiator support. You only need to trim a small amount of metal from the Stagea's radiator support to allow the wider R34 lights to fit in position.
Do they still sell those headlight adapters? Thanks
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
