  • Replies 161
Posted Images
Yeah... a 10cm distance :whistling:
Usually don't have someone hooking under the arms, just ready to assist with the bar shadowing it. When I used to do squats years ago in a supervised environment we were just instructed to drop them, never got assisted. Wrong or down to preference?
Although that was a while ago, could be mixing up the dropping with deadlifts. My memory is terrible.
Edited by JEPPE
down to preference i believe. i've read people say (actually over in the gym thread here haha) that if you're going on heavy weights (where you might have difficulty) then don't use the collars, so that if you really are in trouble then just tip over and drop off the weights. remember that the bar will swing up though haha
^^^ That's only with Benching.
If you're squatting by yourself, you really should be doing it in a power cage with the safety bars there to prevent you crushing yourself or damaging the bar.
You can't spot a squat by shadowing the bar.
unless you want to hurt yourself and the lifter.
Edited by TTT
I suppose it wasn't spotting as much as it was assisting, I get what you mean though.
Have seen people using the cages before, sometimes they seem to do it at obscure angles though. Is it meant to be used as if squatting without a cage?
in a proper comp, you have spotters on either side of the bar too.
Their job is to help lift the bar.
the spotter behind is there to keep the lifter from falling or folding over etc.
Charlie - the safety bars can be removed.
you can do everything in there as the pin height where you put the bar has many heights.
Most of those cages will also have chin up handles on the top and some have dipping bars on the side.
That's why they are great for home gyms.
you get a power cage, a bench, barbell and weights and you can do 99% of what you need.
the best technique in heavy squatting is to have no spotter behind you, and if you fail you just throw the bar behind you.
It's the safest and easiest, and means you don't need a power rack or a spotter to squat to failure.
I honestly can't see how it's possible to get the bar to fall BEHIND you on a squat that you failed due to being unable to lift it.
If you squat high bar and can keep your torso upright, it will be easier to dump the bar behind you.
Low bar and wider stance has you leaning forward more.
That would be hard to dump the bar behind you.
Also depends where in the lift you fail.
If your hips raise faster than your torso (bad form or fatigue etc etc) you'll end up in a good morning type position and you won't be able to dump the bar behind.
Yeah I was thinking this.
Plus I'm in the mindset of low bar anyway, high bar is uncomfortable as all shit for me.
let go of the bar and move forward. Maybe easier with a high bar upright squat but unless you are good morning the squat for some reason it's easy to do with a low bar squat too
Or you could squat in a rack/cage that has safety bars and ass to ground it onto the bars if you can't lift it...
I hate squatting in a cage, everything is so close and i get a bit claustrophobic.
Outside is fine, it shouldn't be that often that you are failing on a squat in training anyway
provided you have bumper plates and a floor that is okay to drop weight on
when at commercial style gyms I squat with no spotter and no safety bars... then you have no choice but to make the lift... you'd be amazed how a bit of panic/fear can help you out of the hole lol (don't do this with 1RM attempts obviously)
I know, that's why i never squat with spotters or a rack.
I guess if you can't drop the weights then use a rack i guess. Spotters are useless imo for squatting when training
Markos posted this on another forum... a must read for girls (make sure you read the last couple of pages)
http://startingstrength.com/articles/training_perspective_gillian.pdf
"In Mark Rippetoe’s words, “Your appearance when fit is almost entirely a result of your genetics,
which are expressed at your best only when your training level is at its highest, and this level is only
obtainable from a program based on an improvement in your performance, in the gym or on the
field. And the best improvements in the gym occur when participating in a program that looks more
like performance athletics – the kind of training done by competitive athletes – than one that looks
like waving your arms and legs around on a machine or slowly rolling around on the floor” (Strong
Enough?, p118)."
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
