Red Light Camera Fine, Vehicle Was Entered The Intersection On Amber.
Hi guys, I just need to clarify my knowledge. As far as I know, provided the lights have NOT turned red (Green or Amber), and your front tyres have passed the line already, you cannot be fined. Am I correct?
I was driving home and there was a security truck in front of me turning left (as was I). When he entered the intersection there was still a green arrow, I'm practically right up his ass waiting for him to turn, he is taking his sweet ass time to turn, I was already in the intersection and got flashed.
Image attached below.
What should I do? Where do I stand with the fine? ($400 + 3 demerits)
Edited by S3RK
As above stated. The fact that there's no truck in frame either makes the argument a hard one to debate and chances of winning are extremely slim. Unfortunately just gota cop it on the chin
i believe all four wheels have to be across the line by the time the light goes red
I've been told all four have to be clear over the line, so yeah. I pretty much "ran" the red... Ohh well :(
No reversing, as above, I ran it.
Thanks for your help guys! Much appreciated.
dude .... take a hint
You mean that a truck was turning and by the time the road was clear the light was red si you where reversing back to be safe
That's what happened isn't it?
not to mention the thread on a public forum with all the details.
sometimes stuff happens, unlucky. on the bright side you still have 2 arms, 2 legs and a car (or if you don't....it wasn't this red light's fault :) )
I'm actually surprised at those cameras, I've got a really high res photo, this is downsized a fair bit. Sunset is amazing :P
That's one f**king expensive photo though xD
Edit: Photo added!
Edited by S3RK
speaking of the photo....does it show a bus queueing right across the intersection, or did you go through after it had time to drive right across?
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
