I'm seeing if there is much interest for my mates damaged s15 needs radiator support replace as damaged to the passanger side no rail damage at all. But the wheel well is damaged also. I cant post pics from the I pad. But I can email but please no time wasters if genuinely interested ask this is an awesome car and in my opinion would only cost 3-5k to fix
Car is in mint condition and looks fat, best stance and very tough
colour white
Needs new - Bonnet, Passenger side Guard, Front Bumper, Passenger side headlight, coolant overflow bottle, radiator support.
The car has 97,000km's on the body and 87,000kms on the engine
Engine / Performance Upgrades
- Standard bottom end
- ARP Headstuds
- Brian Crower Titanium Valve Springs and Retainers
- HKS 272 Degree Inlet and Exhaust 9.3mm lift
- NGK Iridium Plugs
- HELPS Metal Works Steampipe manifold
- Precision 5558 Billet Ball Bearing Turbo .64 rear (Rated to 650hp)
- Turbosmart 50mm wastegate with 2" screamer pipe
- Speedflow Oil feed turbo line
- 4" Intake
- 3" Custom Dump pipe into 3" exhaust all the way through to a Trust Ti Canon Muffler
- Greddy Adjustable Cam gears
- Greddy Timing Belt Kit
- Aeromotive Fuel pressure Regulator
- Walbro 400lph In tank Pump
- Bosch 1000cc injectors
- Aftermarket fuel rail
- Braided Fuel Lines
- Greddy 100mm Thick Intercooler
- 3" Customer Intercooler piping with Turbosmart joiners
- New Seals throughout whole motor
- Standard inlet manifold
Drivetrain
- Supra R154 5 Speed Gearbox with custom extension to fit in Nissan Factory Position
- Genuine Toyota Gearbox rubber mount
- GJ Drivelines Custom 3" tailshaft
- Nismo 2 way LSD
- Cusco Exedy Super Single Clutch
- Genuine Seals right through gearbox and new clutch slave cylinder
Suspension
- JIC Magic Coilovers fully adjustable - 10kg (F) Springs & 8kg ®
- Ikeya Formula front lower arms - might be damaged on one side, havent inspected yet.
- Ikeya Formula Tie Rods
- R33 GTST Tie Rod Ends
- TEIN front castor arms - might be damaged on one side, havent inspected yet.
- JPP Front Knuckles over 50 degree's of lock
- DRIFTWORKS Rear Castor arms
- DRIFTWORKS Rear Tractions rods
- DRIFTWORKS Rear Camber arms
- DRIFTWORKS solid rear cradle bushes
Brakes
- HEL Braided brake line full ABS delete kit - no metal brake lines - all braided through out whole car
- BM50 Brake Master
- R33 GTR V-SPEC Brembo 4 pot Calipers
- RDA Slotted & Ventilated 324mm Rotors
- EBC Red Stuff Brake Pads
- Standard s15 rear Calipers (just been completely rebuilt with new seals etc..)
- GKTECH Handbrake Extenders
- RDA Slotted & ventilated rear rotors
- EBC Green Stuff Brake Pads
- Braided HEL Lines
Interior / Electronics
- Adaptronic e420d Basic Select ECU
- Nardi 350mm Deep Corn Steering Wheel
- Optima Yellow Top Battery in Box
Exterior
- Full JDM Spec R bodykit includes sideskirts and Rear Pods
- DMAX Boot Lip
- Yashio Factory LED Taillights
- HID Headlights - needs new passenger side headlight
- JDM s14 "S" Bonnet Badge
- Tinted Windows
- ROTA Torque (F) 17x9+12 with Federal 595RSR Semi's & ® 18x9.5+20 with 235/45/18
Interested in trades for a nice gtr
Or an na s13 and bulk cash
Cash price 18k
