Selling my unfinished project, dont want to but too many bills.
Its an R32 4 door type m 160000kms with series 2 rb25 conv (motor has 80000kms, purchased off bloodsword from here). Has standard rb20 manual box and ecu (not wired to the 25 yet), the standard rb20 loom is still there plus the lower loom from the 25, I have a Motec m48 with ignition expander that im selling separately.
Car is silver, standard rims painted black, had climate control but needs to be put back in (comes with all parts)
Some mods:
Brand new Walbro gss-342 fuel pump with spare used gss-341.
3" straight through exhaust with 5' tip
Sard fpr
Hdi dual sbc boost controller in ashtray
Boost, exh gas temp and air fuel gauges
Hpi one piece clutch cable (eliminates slave cylinder)
Exedy hd clutch
Body is in excellent condition you wont find many this straight, has the full genuine aero kit including side skirts, paint is pretty good interior is decent, has new middle ac vent, all electrics work including folding mirrors. Got a fair few spare parts left over from the 20 that ill throw in as well.
Bad points:
Does not come with turbo, injectors or cooler though the standard cooler is still in there, and a few months ago i removed the rear windscreen to fix some rust and such and havent put the screen back in yet. The screen has been thoroughly cleaned of all sikaflex etc but needs new rear windscreen rubbers, new tyres and p/steer belt.
There are a couple 50 cent sized rust holes under drivers feet and a couple dings/scratches on the paintwork. Other than that you would be hard pressed to find a straighter 4 door.
Looking for $4000, Im located in Homebush NSW.
Sorry about the photo, at work and only photo i had was my dp will post more tonight.
Thats about it any questions PM.
Edited by brendo.r32
motor needs to be wired up, rear windscreen needs to be put back in, needs turbo, injectors, cooler, dump pipe and intake pipes, tailshaft is out coz of motor change though i could put back in before sale plus clutch cable needs to be installed, needs new tyres and p/steer belt.
  • 1 month later...
  • 3 weeks later...
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
