Hi Guys,
To put things into perspective, this is how rare these things are getting..........
On January 1 of this year, I noted 66 R32 GT-R's for sale on CarPoint, Australia wide of which 18 were in NSW.
Today...... there are only 38 Australia wide, of which only 12 are in NSW.
A good friend of mine comes into some money in February after selling some land and wants to buy my JDM. We agreed in principle but conceded we would finalise things then.
After looking at these numbers I'm getting cold feet, this has even surprised me. They are dropping like flies!
Bob.
  • Replies 128
Hi Guys,
Bob.
i think the thing is more and more people are hanging onto them because of the price of the market at the moment
that being said GOOD QUALITY 32s are as rare as hens teeth i looked for over 18 months before i found mine there are alot of them out there but most are rough or in a condition i would consider track only
confirmed attendance
wingnut999
Sinista32
aaronjod +2 other r32 gtr
SiR_RB
Aussie_Delivered_R32_GTR
vorse
DannyzGTR
DJMGTR
BunsenBurna
MNTL32
DVS JEZ
portaz + friend in gtr
plus about 5 more on facebook so far
will put it up on other forruns
Im a maybe. Depends on work and baby but only live 5min away so should at least make an appearance
It'll be a neat l'il encore after the 21st Anniv Cruise in 2010 and the work you did in Motive DVD #11.
Perhaps some attendees might like you to bring & sell a couple? If I owned an R32 GTR and didn't have that DVD with that massive convoy, I'd want one Andrew!
Yeah......... I'll buy one and I'll be there.... Bring one along for me please. Thanks...... Bob.
Hi Guys,
Update on these numbers....... 30 Australia wide, 9 only in NSW.
Interesting. I see a number of 32 GTRs quite regularly in Canberra but they aren't forum goers that I'm aware of.
Would love to go to this but have something else on the day already.
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
