  • Replies 128
Pushing to get my GTR out of shop by Friday to make this.
Plenum, injectors, tune etc..
Seems now only 1-2 comming up from Canberra :(
Wollongong on the way ?
Have to be where Picton road hits the Hume Hwy
I think Cosa and I are guna aim to be there around 9:30. We are still trying to convince another to come up with us and stop being a pussy and drive his car lol.
Hope you can make it Sin. Im looking forward to meeting you and checking out your machine if you can make it. Ill be rockin your old Clear D-speeds. They look schmik.
I'm heading to Syd for the day but have other plans unfortunately.
Look out for 'crazy' blonde on the highway in a bright red 318is with ACT plates waving frantically :)
FYP
...otherwise people will think you really are.
Look out for crazy blonde on the highway in a bright red 318is with ACT plates waving frantically :)
Detours can be made with enough time :whistling:
Good News / Bad News
The Good News - GTR will be out of the shop late this arv, even stronger !
Bad News - The bill likely stops me from travelling up and back tomorrow. (not finalised yet :unsure: but I have an idea on final cost now and struck a few minor hiccups along the way) that and purchasing a few recent goodies....
If there it will be like Miracle on 34th street
guys, im 50/50 bout today, misses got taken to hospitol this morning at like 1am and im still here
F******N asthma and this heat is a bad mix, most likely thou i wont attend, id rather stat with here
if i dun come down, have a great day guys
hope the weather holds up for you
cheers michael
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
