I didn't think of that Greg, wonder how they'll do that.
it isn't in the factory cluster (at least not on mine).. I looked into this when fitting commsman's CC unit.. you would need to swap the cluster with one that has the indicators..
  • Replies 96
Posted Images
IR cruise was an option. mainly in the 2.5lt cars. to date i have yet to see it factory fitted in anything other than a 2.5.
in regard to switches the later ones are a DIFFERENT caibration to the early ones.
unlike the kit i sell where I load a fixed calibration into it I have a feeling you will be locked to a certain style of switch pending the
calibration used in this software.
food for thought before you go buying switches.
Keen to see how this cruise control/map switching stuff turns out. Had a chat to Matt at ECC About it today when I was down there to buy a Cipher cable.
I'm definitely up for it, I do enough trips between the Sunshine Coast and Brissy or Brissy to Ipswich for work that factory cruise control would be amazing. Would also investigate getting an economy map
Personally, I don't get why everyone is so caught up in the map switching. Someone care to explain it? Sure I understand the benefits of a valet, or even anti theft map.
But really, one map is all thats needed. Economy? well, thats going to be a completly different area of mapping to power, so you can have both! The tuner is only going to change areas of the map you ask him to. If you ask for the bottom end to remain stock, then it will be.
Its like having +11ty boost levels. Why bother, drive with your right foot!
agreed. now if you are doing E85 and normal fuel swapping with the supporting hardware it would make perfect sense.
Some uprev supported ecus have flex fuel option. Unfortunately nothing in Australia. :(
Would be epic to flick a switch in uprev and enable flex fuel.
Really flashing takes < 60 secs with a lappy. Not hard.
not everyone has a laptop or wants to own one.
As for switching between maps, from memory, there are 5 when you enable it. Imagine there are only 3. 1 for your every day where you use your foot to control the show. Now, you could have 1 for when you are not that sure how much fuel is left or when the next petrol station (with 98) is coming up. The last map (of the 3) is for when you want a little more... of everything. Our cars also have a "power" setting for the transmission. I personally do not drive with it on all the time either. There are people who do bungee jumping, I don't "get it", but I can understand that "they" want to. Each to their own, and Everest because its there.
As for reflashing, the switch (if you could understand why) would not require pulling over or carrying around a charged laptop. Plus every reflash does include a risk that something could go wrong (eg laptop crash in the middle of a flash).
To me it's a gimmick.
I bought a $50 laptop just to tune. It's only got tuning software on it. Here's a question, if you get the tune by east coast customs, do you actually walk out with a uprev cable? Or just the car tuned?
this goes back to the days of people bitching about locked motec m8 s . tuner would lock the unit so it could not be fiddled with. customer would bitch because their mate had a cable and could not get in.
at the end of it you pay for work to be done by a shop and bot so you can get in and fiddle afterwards.
if you were doing dual maps on the car then fuel switching would bevthevonly real advantage to me. adding a blower to the car hardly makes twin maps worthwhile on a otherwise stock computer.
And now your starting to get a smidge of an understanding. :whistling:
One other thing I am hoping to get out of a reflash, is an adjustment of my throttle map. I find the first 2cm of throttle is way too much of the full power. When others have driven my car, this has been the first thing they have commented on; and now that they mentioned it, its bothering me. Having multiple maps at the flick of a switch would mean I would not need to make a commitment to something extremely soft/relaxed. And now I am up to 4 maps... :banana:
In the post above by ECC regarding getting our ECU flashed remotely, you also have to buy a cable. I do not understand that (and sent a email to confirm), if they are the ones flashing it. So, it would appear if you do it remotely, we will have to get/pay for a cable. :unsure:
Heaps of guys on G35driver changed their old switches out for the new style with backlit buttons. No one reported that the stereo or cruise stopped working, so if there is a difference it doesn't appear to be enough to cause any issues with factory functions. Any limitations must be in your kit Chris.
I had a Cobb accessport for my mazda MPS which allowed map switching, full control over all parameters and some cool features like flat foot shift and launch control.n
Aside from the FFS and LC, the only maps I ever used were a 'valet' map which limited the car to 0psi boost and 4000rpm and 60km/h - used it once when I left the car at a panel shop. Also had a security map which you load on and it renders the car unstartable until you remove the map, great if you're going away on holidays. Even if they get the keys it won't start.
Other than that I just had it set to the most aggressive tune based on my mods. On a V35 where a tune nets about 20rwkw gain at best, I can't foresee any circumstance where you would need to 'tone it down'. It's like the sport button, who ever actually switches that off??
I agree with you for the most part. However, there is one reason which is the only valid one for me and was the case with the MoTeC M800 in my Maxima back in the day - emissions testing.
Only once did I ever get pulled into an police/RTA inspection bay driving around one night. I switched to my "RTA Map" which basically leaned out the fuel, engaged a less aggressive ignition curve, kept the boost solenoid open and reduced the rev limiter back to 4500RPM. Kept me on the road and out of an EPA building.
Otherwise, you're right. For a naturally aspirated vehicle or even forced induction with very mild mapping, it's not necessary.
I'm using uprev in my N16 pulsar hatch turbo conversion and I couldnt be happier with the product. It's exactly what I wanted out of the car. to retain all the factory cold start and reliability.
I purchased the tuner package and had adam at JEM tune the car. Adam did run into a few initial issues with the software, but that was only due to the fact he'd never used it before.
I myself would love the ability to use map switching, however its not a requirement. It doesn't take that long to reflash the ecu anyways.
I've done a bit of homework with regards to wiring for the cruise control, and my car has none of it in place. It was never an option for the n16 hatches, it was only ever available on the n16 sedan autos.
doing the wiring and installing the additional switches is pretty much a no brainer. It's not hard to compare a couple of wiring diagrams, for that of my car and the b15 sentra(us equivalent) to work out what wiring is missing.
The concern I have is wether the ECU firmware has the ability to receive inputs from these switches and activate cruise control. Which i'm of the opinion it doesn't.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
