I didn't think of that Greg, wonder how they'll do that.
it isn't in the factory cluster (at least not on mine).. I looked into this when fitting commsman's CC unit.. you would need to swap the cluster with one that has the indicators..
  • Replies 96
Posted Images
IR cruise was an option. mainly in the 2.5lt cars. to date i have yet to see it factory fitted in anything other than a 2.5.
in regard to switches the later ones are a DIFFERENT caibration to the early ones.
unlike the kit i sell where I load a fixed calibration into it I have a feeling you will be locked to a certain style of switch pending the
calibration used in this software.
food for thought before you go buying switches.
Keen to see how this cruise control/map switching stuff turns out. Had a chat to Matt at ECC About it today when I was down there to buy a Cipher cable.
I'm definitely up for it, I do enough trips between the Sunshine Coast and Brissy or Brissy to Ipswich for work that factory cruise control would be amazing. Would also investigate getting an economy map
Personally, I don't get why everyone is so caught up in the map switching. Someone care to explain it? Sure I understand the benefits of a valet, or even anti theft map.
But really, one map is all thats needed. Economy? well, thats going to be a completly different area of mapping to power, so you can have both! The tuner is only going to change areas of the map you ask him to. If you ask for the bottom end to remain stock, then it will be.
Its like having +11ty boost levels. Why bother, drive with your right foot!
agreed. now if you are doing E85 and normal fuel swapping with the supporting hardware it would make perfect sense.
Some uprev supported ecus have flex fuel option. Unfortunately nothing in Australia. :(
Would be epic to flick a switch in uprev and enable flex fuel.
Really flashing takes < 60 secs with a lappy. Not hard.
not everyone has a laptop or wants to own one.
As for switching between maps, from memory, there are 5 when you enable it. Imagine there are only 3. 1 for your every day where you use your foot to control the show. Now, you could have 1 for when you are not that sure how much fuel is left or when the next petrol station (with 98) is coming up. The last map (of the 3) is for when you want a little more... of everything. Our cars also have a "power" setting for the transmission. I personally do not drive with it on all the time either. There are people who do bungee jumping, I don't "get it", but I can understand that "they" want to. Each to their own, and Everest because its there.
As for reflashing, the switch (if you could understand why) would not require pulling over or carrying around a charged laptop. Plus every reflash does include a risk that something could go wrong (eg laptop crash in the middle of a flash).
To me it's a gimmick.
I bought a $50 laptop just to tune. It's only got tuning software on it. Here's a question, if you get the tune by east coast customs, do you actually walk out with a uprev cable? Or just the car tuned?
this goes back to the days of people bitching about locked motec m8 s . tuner would lock the unit so it could not be fiddled with. customer would bitch because their mate had a cable and could not get in.
at the end of it you pay for work to be done by a shop and bot so you can get in and fiddle afterwards.
if you were doing dual maps on the car then fuel switching would bevthevonly real advantage to me. adding a blower to the car hardly makes twin maps worthwhile on a otherwise stock computer.
And now your starting to get a smidge of an understanding. :whistling:
One other thing I am hoping to get out of a reflash, is an adjustment of my throttle map. I find the first 2cm of throttle is way too much of the full power. When others have driven my car, this has been the first thing they have commented on; and now that they mentioned it, its bothering me. Having multiple maps at the flick of a switch would mean I would not need to make a commitment to something extremely soft/relaxed. And now I am up to 4 maps... :banana:
In the post above by ECC regarding getting our ECU flashed remotely, you also have to buy a cable. I do not understand that (and sent a email to confirm), if they are the ones flashing it. So, it would appear if you do it remotely, we will have to get/pay for a cable. :unsure:
Heaps of guys on G35driver changed their old switches out for the new style with backlit buttons. No one reported that the stereo or cruise stopped working, so if there is a difference it doesn't appear to be enough to cause any issues with factory functions. Any limitations must be in your kit Chris.
I had a Cobb accessport for my mazda MPS which allowed map switching, full control over all parameters and some cool features like flat foot shift and launch control.n
Aside from the FFS and LC, the only maps I ever used were a 'valet' map which limited the car to 0psi boost and 4000rpm and 60km/h - used it once when I left the car at a panel shop. Also had a security map which you load on and it renders the car unstartable until you remove the map, great if you're going away on holidays. Even if they get the keys it won't start.
Other than that I just had it set to the most aggressive tune based on my mods. On a V35 where a tune nets about 20rwkw gain at best, I can't foresee any circumstance where you would need to 'tone it down'. It's like the sport button, who ever actually switches that off??
I agree with you for the most part. However, there is one reason which is the only valid one for me and was the case with the MoTeC M800 in my Maxima back in the day - emissions testing.
Only once did I ever get pulled into an police/RTA inspection bay driving around one night. I switched to my "RTA Map" which basically leaned out the fuel, engaged a less aggressive ignition curve, kept the boost solenoid open and reduced the rev limiter back to 4500RPM. Kept me on the road and out of an EPA building.
Otherwise, you're right. For a naturally aspirated vehicle or even forced induction with very mild mapping, it's not necessary.
I'm using uprev in my N16 pulsar hatch turbo conversion and I couldnt be happier with the product. It's exactly what I wanted out of the car. to retain all the factory cold start and reliability.
I purchased the tuner package and had adam at JEM tune the car. Adam did run into a few initial issues with the software, but that was only due to the fact he'd never used it before.
I myself would love the ability to use map switching, however its not a requirement. It doesn't take that long to reflash the ecu anyways.
I've done a bit of homework with regards to wiring for the cruise control, and my car has none of it in place. It was never an option for the n16 hatches, it was only ever available on the n16 sedan autos.
doing the wiring and installing the additional switches is pretty much a no brainer. It's not hard to compare a couple of wiring diagrams, for that of my car and the b15 sentra(us equivalent) to work out what wiring is missing.
The concern I have is wether the ECU firmware has the ability to receive inputs from these switches and activate cruise control. Which i'm of the opinion it doesn't.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
