i have a r33 gts, and recently put a m spots bodykit on her, but now it is way to low and scraps on everything, and was just after some ways i could raise the height, i was told coilovers but idk much about them and if they would raise it, cheers
https://www.sau.com.au/forums/topic/414721-r33-suspension/
Those heights are just above the minimum legal height. Means that your car is lowered between 1 and 2 inches. You could try to source some new springs (say King's Springs) in standard ride height, or maybe in low (rather than super low) for a lot less $$ than a set of coilovers. Or you could get some BC BRs for ~$1200.
https://www.sau.com.au/forums/topic/414721-r33-suspension/#findComment-6651866
Stock body ftw. Unfortunately this is a losing situation, if you raise your car it will look ridiculous if you keep it how it is you will slowly destroy it. Unless you drive like its a low car even though its not low, it can be done just take the right angles nice and easy when faceing driveways, speed bump etc
https://www.sau.com.au/forums/topic/414721-r33-suspension/#findComment-6674358
That's the problem with M sports kits. To pull that look off you do need some major low. I was going to buy one but honestly the height issue is why I didn't.
But in saying that I think you'll find that you'll struggle with most aftermarket kits with a lowered car. I had a GTR bar on and that ripped off due to a low ride height, currently I have a 400R and on my coils highest setting it still scrapes.
https://www.sau.com.au/forums/topic/414721-r33-suspension/#findComment-6676088
    • This is a real nostalgia trip for me, I mean SK Bilsteins? I ran those lol Good times.  Good work Duncan, it's not an easy job in many respects. I'm sure the family appreciates it.
    • It's not a dumb question. I was circling this idea myself. User error is always possible!
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
