Like Deca? Wish It Were Closer? Wish No Longer! New Skid Pan In Melbourne!
RTR - 'Road Track Rally' have delivered...... baller style.
Yes, you're seeing correct. A 9000 sqm (i believe) skid pan VERY soon to be available in western Melbourne. Prob 30-45min'ish for those of us on the civilised side of Melbourne :D
Slightly smaller than DECA overall, but i think maybe a little longer... not 100% sure
Not April fools, this is full legit, ready to rock early 2013!!! Bring it!
oooooooooooooohhhhh yeeeaahhhhhhh.........
  • Replies 76
Like DECA?
I see no back track :huh:
As said in the other thread (might have been wasteland), hopefully it doesn't go the way of Drag Tag's skidpan that ended up having the Law sitting out front of it all the time. Although it wasn't built as a skidpan given the main business is Forklifts... So council likely don't know it's going to be used for "that"...
oh yeah, no back track, but 'like DECA' i meant is in the 'affection' variety, not necessarily by it's exact make-up. But still, great to have an autocross venue close by - google tells me 45mins
public events? as long as there is an event you can join, then that's all we need. SAU DECA aren't exactly 'public' events, still need a CAMS/ASAA (or aasa whatever) license. I'm guessing it will be along those lines
i'm sure this is a multi-purpose venue, but will cater for motorsport events.
If anything, this will be a good compliment for DECA, you can do these events close-by but if you want a day mixed with some tight track action, you can go for a DECA.
hahaha, yes Grant, no armco :D
Ye that's cause it's all 100km/h sans the Westgate section :thumbsup:
It's still 25mins from the CBD regardless was my point, as it's being claimed as "10mins", which is just rubbish as it takes 10-15mins to get the the WGB from the CBD - i do it regularly
this isn't a workshop war thread, not that there is one going on, this is just to let you know we all will have a DECA (skid pan) sized facility available to us for autocross events. That's it, we should be all grateful for having motorsport facilities closer to us... isn't that what we've always called for? Yes it isn't another metro track like Sandown, but good luck that happening. And no there isn't a back-track like DECA, but it's still potentially a great facility to have some safe fun, that's pretty easy on the car.
10-20mins whatever, all i know is that more close motorsport venues the better, no?
You must drive slow I regularly do point cook / hoppers crossing to city in 15-20 mins
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
