Yes Joey, drag slips, its the only way to be sure, I'll race you for beer (no more little bloody donuts, bastards).
You will though need to spot me 5.5 seconds though.
I'm guessing you might run a 10.5ish where I might run a 16ish
Come on, my 5 has at most an astounding 80 to 90 killerwasps at the back wheels.
Put It this way, my old RWD boat on old drag radials and 380kw got a 11.008, I'm sure there's a 10.5 in yours.
The box should be fine for the first couple of runs, it might sound a bit like industrial exhaust fan after that though.
In all honesty if you take off easy and don't shift to hard the box should be fine, I believe its the drag radials and big launches on the sticky stip that eats the 1-3 gears.
Ill give you 4.9 seconds then, with a 6 pack of Crownies on the line.
EDIT: First gear?, with your torque the only time you will use first gear is in the lanes before the water box
Righto,
take this as you will, i consider that engine capacity, cams, fuel makes it a "similar" comparison
So same dyno
Both set ups have
2.6L
both have standard compression from memory
similar drop in cams
high ethenol content fuel
Both have large sufficient exhaust, ignition and fuel setups
Mine is the orange/red line
-5 line is black
To be fair, that -5 result im comparing against wasnt the most responsive run out of them all. But that particular result did flatten out alot after 5200rpm and my curve was still fatter
I dont know if i want to test the waters.. maybe when i get a stronger box.
I would have just got the thing on the road and i dont feel like spending more $$$ to keep driving it haha
Oh yup similar looking results to what I got just bait higher because of the ethanol.
I might stick with the -5's until i upgrade my injectors/gearbox and then go with a 8374 1.05 A/R as my bottom end has been built to withstand hell.
and I hear you about popping the standard box. Why I haven't run mine yet.
It's interesting to note that there is very minimal change in power between E45 and E85 on our boost levels. It's only an extra safety margin..
I'll be running 50/50 as a more common everyday mix
Lol, lies, I see lies :P
You can't really compair single v twin cause to many veriables like intake and dump pipes etc, dump pipes are one of the biggest issues with turbos and it's hard to get wrong on a single, especially if you have a external gate, but very very easy to get wrong on factory mount twins
Even cam timing makes a difference
So it really comes down to personal preference and what you want from your car
Haha, maybe, doubtful but maybe, but twins will get you there quicker :P
Take matty from WA's experience. Twin -5's on a 3.0 and went to a 8374/0.92 internally gate single. The EFR was back to peak boost levels in a 1/3rd of the time the twins took (Motec logs), made more power everywhere also.
However, it would be interesting to compare something like the 8374 EFR to say twin 6258 EFR's.
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
