Very impressive. How far away from a dragway? Interested to see the results!
The surge tank makes for a very tidy installation compared to others with multiple pumps. Any idea of the fuel capacity of the tank?
Two 38mm wastegates flow more than a 50mm and less than a 60mm - what is the reasoning for having two rather than one with a single turbo?
And what size and type of bov(s)?
Only about 20 min from the drag strip mate, should hopefully get down there before the end of the year, hopefully make a 10sec pass :D
Capacity of the surge tank it 5L from memory
Like Paul said, running the twin gates cause I wanted to keep it a true twin scroll set up
BOVs are just the standard ones but vented to atmosphere
Nice result joey. This gives me hope the 88/75 with full race mani on the 30 will be worth the wait.
Interesting to see how this goes.
More specific details of the setup?
How did you guys get the boost to come in so much earlier on the orange line?
Looks like by turning up the boost from 20 to 25psi
and I quote:
"The only difference in the two lines in the graph is that there was more boost added to the mid range for when i wanna bump up the power for the drag strip"
I think, and this is my explanation until I actually ask the tuner, because the boost was higher in the second line through the mid range.. The boost controller held the gates shut tighter not allowing any leakage.
there was no changes besides the extra boost through the mid range
Correct me if I'm wrong, but assuming the 32GT-R BOVs are the same as a 33GT-R they're gonna be sitting slightly open when in vacuum and as a result be sucking in (a very small amount) of unfiltered air.
Not sure how concerned you are about that, but it's the reason I stopped using my stock 33GT-R BOV and switched to a proper atmo.
Haven't even really thought about it mate, to be honest I'm not overly concerned, I don't think there is anything to be too concerned about :/
I would rather keep the standard BOVs
Haha vids this weekend :)
That's pretty much the limit of that turbo, we put more boost into it but it just want making any more power.
So we backed the boost off up top and beefed up the mid range..
Yavuz wants to put a precision on it lol
I just need to install a second 044 pump in mine and run the lines and mine will be ready for a tune with the 6262, if you hold off until then might give you an idea if you want to swap and if you do go the same or bigger
Ah excellent, are you still running a 2.6? what work have you got done to your head?
once the Tune was done we ended up taking the BW off and bolting in a 6466, didnt quite line up at the dump pipe though, other wise i dare say id be running around with Pauls turbo right now haha
Yavuz reckons response would be the same if not better and it wouldnt choke so much up top
Well after seeing the power it made on pump on low boost (around 375rwkw) i would have thought it would have made more power...
but by the time we played with the cam gears and got boost coming on nice and early we lost that little bit up top
at the end of the day the front fan is only 60mm and for it to make that power with that kind of response, i couldnt have asked for much more really :)
once the Tune was done we ended up taking the BW off and bolting in a 6264, didnt quite line up at the dump pipe though, other wise i dare say id be running around with Pauls turbo right now haha
Little surprised it didn't make more than that, though still very stout power. Keen to see video :-)
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
