Hey guys,
as some of you know i am ironing out all the minor probs with my R32 and getting it ready for the drags.
I have been talking to Toshi over email ragarding a tuned chip for my standard ECU.
when i emailed him my last dyno-sheet (as below) he explained that the injectors are already at 100% duty.
as you can see the engine does cut out at 5500rpm (I have always thought this was the AFM signal maxing out) is it the injectors? what is the max power std RB20 injectors make?
This dyno print was using just over 1bar (anything under 1bar i have no cut-out problems)
Cheers
Ben.
12.8 A/FR up top is getting a tad too lean for my liking! Are you sure it's 'just' your injectors? What fuel pump are you using? What's your fuel pressure doing across the rev range?
well I would be lowering your boost immedatly as you engine is at risk from running too lean the max power of the rb 20 injectors is around 250 hp@ the wheels or 195 rwkw you will need bigger injectors and a z32 afm
btw this is one of the reasons I went sr rather than rb 20
cheers
meggala
Yep, I agree with Meg's, wind the boost down till you get it sorted.
I know Clint (Clint32 from SA section of SAU) got 230rwkw (308rwhp) out of his RB20DET injectors. I'm not sure what fuel pump, reg, or pressure that was with though? He ran 12.8 @ 113mph with that power level.
Nice dyno and 1/4 numbers too Meg's!
Yeah dont worry about me running that boost, because it is running at 12psi only.
but as a few of you said, i thought the injectors would have a little more in them.
I am running a 650hp intank bosch pump and sard adj reg, so the rest of the fuel system should be able to cope.
Would my cutting-out problem be AFM related. i wound the boost uip the otherday, it went to 1.2bar but as soon as it reached around 5500rpm it would cut again...
considering that many have gone 230rwkw on std injectors should i really bother as i only expect i will make around 220rwkw once tuned and boost raised?
Do R32 RB20s have fuel or boost cuts, i never paid too much attention as my old ECU had them removed...id suggest giving Doctor a buzz as he is using my old ECU, but i think he is OS on holidays.
I suspect its the std ECU measuring too much airflow and ending the party, so more the ECUs fault then the AFM.
I didnt want to have to bother with a Z32 meter, and i still dont believe that they are 100%necessary, but the person tuning my car made it pretty clear that he thinks its needed and wanted me to install one.... so to make sure the tune is what i want, im getting a Z32 AFM, but at 200-220rwkws i dont think they are a MUST have, though its not a bad idea to have one if you can afford it.
check the filter thing on the fuel pump too.. i know its a bitch but this car block fuel to the motor obviously - if there is shit on it.. also check the wires to the fuel pump. mine unconnected it self once and made the car a bitch to drive.. taking corners at low speed and made it jerk like i hit a brick wall..
I know there are no problems with my fuel system, everything is brand new and works perfectly well.
I suspect Roy is correct assuming the ECU just craps itself and doesnt know what to do.
well I might buy a chip off Toshi with all the cut outs and limiters removed and see what happens on the dyno. might run a little more fuel pressure and then fine tune the SAFCII (and before anyone asks, i had the boost cut issues before installing the SAFCII)
Seeing as there are a few other making good power with std injectors i will leave them alone. Troy i also agree with you that its not neccessary to go Z32afm at this power level.
Here is my print out. Std injectors and no adj fuel reg. It is 2530 (i think) running 1 bar...and clutch isn't holding up, mind you it's standard...lol
My injectors have got alot of life still left in them by the look of the std ecu AF curve.
BTW this is a comparision between Toshi's chip and my std ECU. He made this chip without seeing my car.
Regards,
Scott
BBenny i can confirm that the cut out you are getting is your AFM. When i had the Std AFM i could see at about 1bar it was hitting a max of 5.1V.
Im sure your fuel system should cope but its the AFM that will give you that cut off.
Ive heard of people with 230kw with std inj and AFM. but realistically that cant be too healthy as your tunability is right up the top of your hardware with inj. and AFM close to their max.
If i were you and was on a tight budget or dont want too much higher in power i would get a Z32 AFM and increase the fuel press. a tad. 220kw is just around the corner...
yeah i have mixed feelings about going Z32AFM.
having done a fair bit of reading on the topic i have found there are two primary arguments for and against, and to me they both make alot of sense!
the first is what you are describing jnr32r - that it is impossible to tune correct airflow readings at high boost/rpm because the std meter runs out of resolution. and installing the z32 (which uses a lower voltage reading) allows you to obtain accurate readings at high rpm.
the other argument against the z32 is that if you have a decent tuner they should be able to tune your computer or ecu regardless, and ensure a safe A/F ratio. and the only time to replace is if the factory AFM size is restricting flow.
So i dont know which to go, obviously if i can get someone to safely tune without the z32 i can save good $$ for other mods, however if it means piece of mind and insurance on my engine...
what does everyone think!
Hi bbenny, I don't know any tuner "decent" enough to tune past 5.1 volts on the RB20/25DET AFM with a standard ECU and an SAFC. The SAFC bends the input signals to the ecu but I don't care how clever they are, the tuner can't get past the basic logic of the ecu. This is of course not the case with aftermarket ecus' where we can program the throttle position and rpm to cover for the afm voltage being at 5.1 volts for long periods.
Keep in mind that tuning an RB20 to run a Z32AFM with an SAFC is not a simple task. You will need a "decent" tuner for that.
im not going to attempt to tune the SAFC to run a z32 AFM as i have heard to many horror stories of ppl attempting it.
I am having the std ecu rechipped shortly so if i decide to upgrade the afm i will do it then.
but i would prefer to not buy a new afm and upgrade to GTR cams and/or adj cam gears...
but if it comes down to not being able to correctly tune the ecu without the afm upgrade, i guess i wont have any choice...
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
