Sure.
It's a super fine version of sand blasting. Most of the blasting material is water which means it can be used on the super soft metals. The guy then adds various different elements to the water to alter the abrasive effect. He uses a lot of the normal blasting medium (sand, walnut, etc). He normally hits it with the harsher abrasive first to clean it up then finishes it off with the fine stuff to create the like new finish.
I had 2 rocker covers, 2 cam gear covers, 4 exhaust manifold heat covers, 2 engine mounts, coolant and oil hard lines, inlet manifold plenum plus a few other random bits and it cost me $125.
The guy is here in Melbourne. His company is Auld Tyme Auto Resto Services and Wayne is the man to speak to. His number is 0416310662. Very nice guy and even picks up and drops off if he's in the area.
Highly recommend his work!
  • 3 weeks later...
So after about 7 or 8 weeks wait, my sexy, sexy slugs arrived-
20F75A88-CB35-4C0B-8E66-E8C5B3849856-300
3AD47DC3-252C-4E0D-B941-3B12FE26E8C5-300
65320665-0305-4CDC-A4DC-C99BF4E92D72-300
That's the positive side of things.
Negatives? I had hand surgery last week to fix some thrashed ligaments in my fingers and thumb from old footy injuries.
Suffice to say I'll be out of action for a while..
9FCBD147-F6B7-418D-8A4E-73F3750C7E18-300
7B7F67A0-AE6B-4E40-9C5B-24C66B758DFE-300
Might also be moving from Melbourne back to Shepparton soon which will be a bit of a speed hump as well. Until I get my 3 bay shed built with barn section in the middle to allow for a hoist........ can't wait.
Be great to be 3 kms from DECA and a lot closer to Winton too!!
Hooray for the pistons turning up!
Not so much for the hand surgery.....does not look enjoyable! Coincidentally my old man just had surgery to fix his carpal tunnel syndrome in his right wrist. Apparently its quite common in mechanics and tradies who often use hand tools. Shunting spanners, ratchets and breaker bars with the palm of your hand to crack nuts/bolts is a primary cause! So there is something to be weary of in the future!
  • 3 weeks later...
So officially moving back to Shepparton now. Gunna be a massive pain in my motivation.
New job, renting house with no shed until new house/shed built, another baby on the way, it's all happening! Will need to try VERY hard to keep on track. Won't get anything done until after the move because of my hand surgery.
Once shed is built and car is finished it will be awesome being back in Shepp. DECA, Winton, back roads!
I'll be working as sales manager for Subaru, Jeep, Dodge, Chrysler, Alfa, Fiat and Mercedes so if anyone needs a new car.....
  • 2 months later...
Long time no post! Been busy with busted hand, moving from Melbourne to Shepparton, new job, new rental house, building new house, etc etc.
Finally started on the car again last week. The engine should be finished the machining stage next week and then I just need to go and pick it all up then start bolting it together.
This is all I've done lately-
Started making the bolt ons-
These, look pretty-
Hopefully more to come soon.
Got a few photos of the machining process.
Bore and hone of block, head ported a little bit, head machined for 1mm oversize valves, block drilled for RB26 headstuds, reliefs grounds for sump adapter allen head bolts, Hardblok up to bottom of lower welch plug holes plus a few other bits and pieces-
  • 4 weeks later...
Finally all of the machining work is done on my engine so I drove to Melbourne today to pick it all up.
Set up the "operating theatre" ready for business-
All the goodies-
Pistons individually weight matched (blueprinted in other words)
Oversized valves in-
Tomei Poncams-
Oil return galleries enlarged-
Intakes opened and tidied up a bit-
Exhaust ports opened up a bit-
Spacer for timing belt tensioner-
What all GT-R's should have had from factory.....-
That's everything that the machinists have done, now it's my turn.
Didn't waste too much time on it but gave the crankcase a bit of a tidy up-
Also opened up the oil return galleries in the block to match the head gasket. The block opening is about 6mm smaller than the gasket which is just bloody stupid!-
Also opened up the water galleries in the block as well. you can't really tell but I've done the main curved bore water galleries as well-
That's all I got done today, still a bit more cleaning up and measuring before I start assembly. Sorry for the photo overkill!
  • Like 1
I had an SR20DET that I was going to put into my other 1200 but reallocated all the funds to the Skyline. I'll revisit that project again at some point. When I have money again. Ie. never!
Great read mate, looks like it will be a very well rounded engine when its done. Great to see you doing it all yourself, would love to have the skillset that allows me to build my own engines!
    • Unfortunately,  it feels like it's been on the decline for nearly a decade. Especially as wallet racing became popular with them(biggest wallet can pay off a car that wins). It seems like a different mindset kf ownership these days. But, hopefully people like yourself keep some of the skyline scene alive.
    • A bit of data is always good, beats the Facebook experts with their opinions Although the kWs aren't anywhere near what you are after, it should give you a good indication. I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
