Sure.
It's a super fine version of sand blasting. Most of the blasting material is water which means it can be used on the super soft metals. The guy then adds various different elements to the water to alter the abrasive effect. He uses a lot of the normal blasting medium (sand, walnut, etc). He normally hits it with the harsher abrasive first to clean it up then finishes it off with the fine stuff to create the like new finish.
I had 2 rocker covers, 2 cam gear covers, 4 exhaust manifold heat covers, 2 engine mounts, coolant and oil hard lines, inlet manifold plenum plus a few other random bits and it cost me $125.
The guy is here in Melbourne. His company is Auld Tyme Auto Resto Services and Wayne is the man to speak to. His number is 0416310662. Very nice guy and even picks up and drops off if he's in the area.
Highly recommend his work!
  • 3 weeks later...
So after about 7 or 8 weeks wait, my sexy, sexy slugs arrived-
20F75A88-CB35-4C0B-8E66-E8C5B3849856-300
3AD47DC3-252C-4E0D-B941-3B12FE26E8C5-300
65320665-0305-4CDC-A4DC-C99BF4E92D72-300
That's the positive side of things.
Negatives? I had hand surgery last week to fix some thrashed ligaments in my fingers and thumb from old footy injuries.
Suffice to say I'll be out of action for a while..
9FCBD147-F6B7-418D-8A4E-73F3750C7E18-300
7B7F67A0-AE6B-4E40-9C5B-24C66B758DFE-300
Might also be moving from Melbourne back to Shepparton soon which will be a bit of a speed hump as well. Until I get my 3 bay shed built with barn section in the middle to allow for a hoist........ can't wait.
Be great to be 3 kms from DECA and a lot closer to Winton too!!
Hooray for the pistons turning up!
Not so much for the hand surgery.....does not look enjoyable! Coincidentally my old man just had surgery to fix his carpal tunnel syndrome in his right wrist. Apparently its quite common in mechanics and tradies who often use hand tools. Shunting spanners, ratchets and breaker bars with the palm of your hand to crack nuts/bolts is a primary cause! So there is something to be weary of in the future!
  • 3 weeks later...
So officially moving back to Shepparton now. Gunna be a massive pain in my motivation.
New job, renting house with no shed until new house/shed built, another baby on the way, it's all happening! Will need to try VERY hard to keep on track. Won't get anything done until after the move because of my hand surgery.
Once shed is built and car is finished it will be awesome being back in Shepp. DECA, Winton, back roads!
I'll be working as sales manager for Subaru, Jeep, Dodge, Chrysler, Alfa, Fiat and Mercedes so if anyone needs a new car.....
  • 2 months later...
Long time no post! Been busy with busted hand, moving from Melbourne to Shepparton, new job, new rental house, building new house, etc etc.
Finally started on the car again last week. The engine should be finished the machining stage next week and then I just need to go and pick it all up then start bolting it together.
This is all I've done lately-
Started making the bolt ons-
These, look pretty-
Hopefully more to come soon.
Got a few photos of the machining process.
Bore and hone of block, head ported a little bit, head machined for 1mm oversize valves, block drilled for RB26 headstuds, reliefs grounds for sump adapter allen head bolts, Hardblok up to bottom of lower welch plug holes plus a few other bits and pieces-
  • 4 weeks later...
Finally all of the machining work is done on my engine so I drove to Melbourne today to pick it all up.
Set up the "operating theatre" ready for business-
All the goodies-
Pistons individually weight matched (blueprinted in other words)
Oversized valves in-
Tomei Poncams-
Oil return galleries enlarged-
Intakes opened and tidied up a bit-
Exhaust ports opened up a bit-
Spacer for timing belt tensioner-
What all GT-R's should have had from factory.....-
That's everything that the machinists have done, now it's my turn.
Didn't waste too much time on it but gave the crankcase a bit of a tidy up-
Also opened up the oil return galleries in the block to match the head gasket. The block opening is about 6mm smaller than the gasket which is just bloody stupid!-
Also opened up the water galleries in the block as well. you can't really tell but I've done the main curved bore water galleries as well-
That's all I got done today, still a bit more cleaning up and measuring before I start assembly. Sorry for the photo overkill!
  • Like 1
I had an SR20DET that I was going to put into my other 1200 but reallocated all the funds to the Skyline. I'll revisit that project again at some point. When I have money again. Ie. never!
Great read mate, looks like it will be a very well rounded engine when its done. Great to see you doing it all yourself, would love to have the skillset that allows me to build my own engines!
    • Not specifically the revamp Toyos. In the past I've used Nitto NT01s, which were essentially the same compound as R888 with a different pattern (that's what the internetz said, so just be facts). I did like the NT01, progressive fade, didn't go from grip to 0 grip in a split second. If you look at the serious street/track guys, most are either on Cup 2, A052, A050, AD09, CR-S or AR-1.
    • I have one of these! It is absolutely useless. It provides not nearly enough force on the bolt, it just slips over anything that is not finger tight. And if it's finger tight, you can use your fingers.
    • You have to take photos of the car in Victoria with a timestamp. So if you have big aftermarket turbo in your engine bay, your car is simply not getting a RWC and you'll be doing a lot of returning to stock, and re-modding after about 90 days (because cars that have had a RWC can be audited after the fact). The law I'm kinda ambivalent about. I can see the logic and the writing on the wall, Cobb etc would be well known for selling to 'wink wink off the street usage' but in the real world everyone knows what they do and where they end up. It'd be like someone selling guns in Australia but "only to people who have a proper licence" but selling them outside of Bunnings instead of sausages to anybody. Like RWC's, and VASS's and EPA, this is enforcement of the actual existing rules. I haven't looked into it but there (should) be a way for people to legally pass their tuned car to be within the rules if they can prove they pass emissions laws that are applicable. If there's not then that's another story.
    • Interesting post(haven't watched the vid). I'm surprised companies can be fined for selling products that are specifically meant for certain applications.  How can you force a customer to use or apply your products in 100% the way intended? People have been misusing products since they were invented. Heck, I ate dessert last night with a soup spoon. Does that mean the spoon manufacturer could be fined? And what of the customers who actually want to use the product for its intended use?   I'm sure we could discuss and debate this for a while, but this is an introduction thread and I dont mean to take over it.
