Phew! My ATI is the 1000HP version so fingers crossed it's all good.
I'll be at the point of putting on thebalancer fairly soon so I'll soon know!
Thanks for the heads up.
Only done bits and pieces the last few days. Been bust doing family stuff for Christmas and went back to work between Chrissy and New Years.
Fit all my nice shiny new coolant pipes into the block. No corroded fittings for me thanks! Nothing worse than stuffing with coolant hoses under the inlet manifold.... I've got all new genuine coolant hoses to fit when I reassemble it all. The last hoses lasted 19 years so I'm sure the next lot will do much the same with how little I'll drive it.
Head studs are all in so I'm nearly ready for some head....
As a mini side project i had a bit of a tidy up of my sink area in the corner of the shed. Put up some $3 sheets of particle board and mounted a stainless splash back above the sink. Put up a shelf, a dart board and mounted one of my stupidly large quantity (about 8 or 9 at a guess) sets of spanners just to free up some space in my toolbox.
I'll give it a quick lick of paint later today if I can be bothered bearing the 40 degree temps out in the shed.
I also need to confirm that my valve clearances are correct in the head before I bolt it on so that'll be another job for later. At some point during one of my two house moves some of the buckets fell out of the head and mixed up a few of the shims so I might need to swap a few around to get them all within spec. Annoying little things like that can be quite time consuming. Takes farking ages each time to take the cams in and out.
Valve clearances are a bit all over the shop so need to order some new shims.... Tried swapping a few shims around but still have a few clearances out of whack. Sick of pulling cams in and out a few times I'll tell you....
With slightly lumpier cams and heavy valve springs it's a bastard. I also discovered that with oversized valves and greater lift the valves can touch if the same lobes are at full lift on the same cylinder..... Thankfully no damage, could have been a costly discovery.
Finished off my little man cave sink corner-
Rear plate and rear main in, sump adapter in place ready to be bolted on next foray into the shed. It needs to be done at the same time as the sump as there are bolts along the front and rear that go through the plate rather than locking the plate to the block like the rest of the flush cap head screws. The photos might explain what I mean (countersunk holes along the side and standard drilled holes front and back of the engine)....
I had a look at the sump and I've decided I'll attack it with the die grinder before putting it on as there is a bit of a lip (3-4mm) that would stop all of the oil draining out during an oil change. The claggy oil sitting on the bottom of the sump is the stuff you most want to get out so I'd rather avoid that if possible.
Looks a bit rough but hard to get into the sump with the die grinder!
Had to remove the standard studs out of the sump to allow for fitting the sump adapter. Trial fit the sump to check clearances and checked pickup depth to bottom of the sump. All looks pretty good. Sitting at about 10-11mm from the bottom so all good.
Trial fit the sump about 4 times which is a bloody arduous job! They're such a big heavy cumbersome thing! If it was evenly weighted (not with the diff hanging way out to one side) it would be a lot easier to manhandle but alas, it isn't, it's a prick!!
Still waiting on a few shims to tidy up some of the valve clearances a bit before I bolt the head on. I could put it on now but a lot easier getting cams in and out with the head on the bench. It makes it a lot easier checking the valve locations now that I know the intake and exhaust valves hit at full opening....
It's a frustrating part of the build at the moment, I'm getting lots done but it's all time consuming stuff modifying things to suit the different setup. When you strip an engine and just reassemble the same thing it's easy but when a lot of new things are thrown into the mix it makes it a lot more time consuming.
All part of the "fun" I guess!
Im going to build one of these simps soon. As i did one for a rb25. And came out great
Seeing how i did it myself i wont have them little problems bung wise. Lol great build mate. Love this post. Keep up the good work.
Didn't get a lot done the last few weeks. Always excuses popping up...
Anyway, here are some further progress pics-
Sump going on-
Ready for the head to go on-
Head on-
Yes they're two generations of Tomei timing gears. I actually kind of like the difference. Not that it'll matter once the trigger kit cam pickup goes on-
Got my hoist bolted down and tidied up the shed a little bit anyway.... Just waiting for the electrician to come and wire it up and I'll be in heaven!
I've got a week off work coming up so hopefully I can get a bit more done on the engine then.
  • Like 3
  • 1 month later...
I've been tied up concreting garden borders, fixing my Kubota tractor and generally piss farting around not concentrating on the car. My Datto 1200 ute finally made it's way to it's new home after being in storage at my parents place for 3 years. It was almost like a barn find it had that much dust and bird crap on it! It's another distraction I don't need. I've already started ordering parts for it....
I've only done a few little bits and pieces on the engine. I'm prepared to be set alight by the haters here but I bought a Freddy intake manifold. A) to help with the aledged leaning off in cyl 6 and B) because it looks good! Performance wasn't a factor but if it helps then great! The quality was pretty shit. I had to get the mating faces of the two halves to the manifold machined as it was a bit warped. I also port matched it to the gaskets so it should flow perfectly now. In terms of the thickness of the alloy that I have seen questioned in the past it was fine. I drilled at tapped 2 holes in it for MAP and IAT sensors and it was plenty thick enough for that.
Hopefully get the intake manifold painted in the next few days and I can get stuck into it again.
Hoist in and car up-
Freddy-
Masked up ready for painting-
I've "ceramic" (high temp paint anyway) coated my exhaust manifolds so we'll see how resilient that is. I need to heat cycle them to try and lock the paint in place-
A snap shot of my next 6 years of spare time....
I'm getting reverse cycle air con installed in the next few weeks so hopefully that makes life a little more bearable all year round! Less excuses then anyway!
Painted the intake manifold last night. Going for wrinkle red. I can't find any photos of it done before so not sure how it's going to look with all of the engine covers, turbo pipe, etc in black and the intake red. Be nice if it looked (and went!) like a Ferrari!
Is it just me or does this photo make the manifold look like it's floating...... Nah, just me!
First coat and cook-
Finished. Didn't wrinkle quite as well as my past efforts have but I still like the textured look even without the wrinkles-
Next up I need to try and work out where the fark all the other little fiddly bits and pieces a) have got to after moving house twice since dismantling the engine and b) go on the engine! My recollection on both a) and b) are pretty bloody foggy after 3 1/2 years of being dismantled. I'll be relying on a lot of Google images and good old trial and error!
I set the goal of having it running by the end of March but sadly that is drawing near and not looking likely. If I can at least get everything done to the engine apart from bolting it back in then I'll be pretty happy.
  • Like 2
Didn't get much done this weekend which is shit considering it was a long weekend....
Painted the balance tube (??) section of the intake manifold. No prizes for guessing what type of paint..... I'm pretty sure the only items not wrinkle black will be the plenum of the intake and probably the fuel rail which will both be wrinkle red. I hate Essendon footy club so not sure about the colour scheme...
This section is pretty much ready to go onto the head now, just need to decide what happens with the throttle body section. It will be bloody hard to paint neatly so it might go in the too hard basket......
At some point I'm going to get over painting shit so stay tuned for some not painted stuff getting whacked on fairly shortly...
  • Like 1
Oh yeah, also I put all new genuine hoses under the intake manifold. If it worked for the last 20 years it's good enough for me to use genuine again! Cost an effing bomb though..... :dry:
  • Like 1
Nissan.
Probably could have saved money elsewhere (Amayama, etc) but one of my mates (unfortunately no longer) was spare parts manager at my local Nissan dealership so he always looked after me.
    • Unfortunately,  it feels like it's been on the decline for nearly a decade. Especially as wallet racing became popular with them(biggest wallet can pay off a car that wins). It seems like a different mindset kf ownership these days. But, hopefully people like yourself keep some of the skyline scene alive.
    • A bit of data is always good, beats the Facebook experts with their opinions Although the kWs aren't anywhere near what you are after, it should give you a good indication. I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
