Been committing a fair bit of time in the shed lately. Doesn't seem like I've done much though.
Dialled in the cams. They were spot on recommended specs at 0 mark on the cam pulleys so that's re-assuring!
Stripped the front bar, intercooler, etc off. Putting new (old!) intercooler on plus all new pipes and hoses for intercooler from turbos to plenum.
Had to remove the ABS module to be able to get the engine harness out. Wasn't happy about having to do that but ah well!
I felt I'd done enough to deserve this sticker....
Dropped the trans out to replace with a rebuilt (cryogenically hardened gears allegedly) gearbox-
  • Like 1
This has been one of my favourite builds on SAU for a long time (that's because it's been going for a long time :P) mate. Good to see it getting towards the good end of the build that's for sure. Keep up the updates, can't wait to see it finished
Edited by iruvyouskyrine
Started stripping the wiring loom to rewire it for the new ECU plugs and to add the additional sensors. With the terminals backed out oof the ECU connector it looks a bit like Medusa's hair do! Unfortunately the terminals are different in the new plugs (Deutsch style) so I'll have to chop them all off and re-crimp on the new ones. I want to try and neaten the wiring up a bit but can't really see a way to do it. I'll run a few wires inside the guards but most will just stay as they are.
Ripped the transfer case off the gearbox and was going to just give it a wash and bolt it on to the new tranny but thought "nah, I'll f#$k my brain even more and rebuild the transfer case while I'm at it. In hind sight it was bloody lucky!
This is the reason why, when I separated the cases this fell out of the bottom-
Which when I pulled it all down resulted in this-
Potentially it was gunna go boom at some point!
It was well and truly due for a rebuild (gravelly bearings, blocked filter, bloody filthy etc) so glad I decided to do it now.
It took me a good half a day to clean everything up to be ready to be reassembled but she's good to go once the new bearings and seals arrive. I'll be playing around with the plates as well to do the "transfer case mod" as it's known. I've got a spare set of discs (and a chain luckily!) so hopefully that makes a nice difference.
  • Like 1
Thanks for the very kind words. Yeah it's been a bloody drawn out process I know! Getting pretty close now so it'll all be worth it soon (I hope!!).
I will be pooping washers when it comes time to hit the key for the first time!
Finally sorted out my turbo oil drains. Was a pain in the arse to get right. I wanted to have both drains going back in to the main oil return but it was just too hard. I ended up using one of the extra AN fittings I had welded onto the sump. I recommend anyone doing an RB30 conversion to do the same. It turned out fairly neat in the end. My poor AN fittings got a bit scuffed from having to remove them a few times.
Almost worked like this but sat a tiny bit too low and hit the drive shaft-
I tried a 45 degree angle but that then lined everything up with the exhaust so back to the drawing board!
Ended up like this with individual drains. All flows nicely now with good angles, still had to angle everything to keep it away from exhaust and other components-
  • Like 1
Ripped the K-frame out so I can install the engine and tranny from underneath. There's so many things that need painting or cleaning but I'm trying to get it done rather than this turning into a full restoration at the same time. I know I should but I want to get it up and running and if I can be bothered going back later for a resto then great! I learnt on a previous Datto Ute (not my current one) that if you get too deep sometimes you can get so far into it you feel like you're drowning and give up. I'm still painting heaps of stuff don't get me wrong but stopping short of going the whole hog. Some things I'm just doing a quick blow over with some paint to tidy up for now which is a bit rough but meh!
Anyway, a few picks of the car sans K-Frame and front hubs-
I thought I'd do something a bit different this post and do a quick video update instead of photos. I did the video unscripted and pretty late last night so hopefully I don't sound like a complete nuffy!
One thing I discovered is I really hate the sound of my voice!
Anyway, see what you think. If general consensus is that it's shit then I promise to never do it again!
  • Like 3
Thanks guys. I'll post up another vid once I've done enough to justify it...
As per the video I fit the cam sensor component of my trigger setup (1/2 Hi Octane, 1/2 Ross.
Also fit the balancer for the first time.  I'm leaving off all of covers so I can check for leaks and make sure the cam belt is all fine once it's up and running
As a side note, below is a list of all of the bearings required for a transfer case rebuild.  Ignore the last bearing on the list as that's the A/C tensioner pulley bearing that I pressed out and replaced ($7.60 instead of $160 to replace the whole pulley...)
In addition to the bearings every seal in the transfer case came to about $130 (genuine). So all up around $200 in seals and bearings to reco it.  I'll be reusing the clutch plates and adding some spares I have to change the friction/driven plate combo.  Obviously it would add extra $$ to replace those too.
Farken wiring...
Coming together nicely mate. Those braided lines are definitely a pain to make sure no exhaust components or intake pipes get in the way. I did it with engine in and took ages to get the right lengths.
Definitely jealous of that shed/workshop setup you have.
9 hours ago, Nismo 3.2ish said:
Looks like you dropped a plate of rainbow spaghetti , lol
Any ideas when you could be turning the key , motors looking mad
Thanks Pete, mate I wish I knew when it would be, it's starting to hurt not driving it!  I've got a few days off next week that is purely for working on the car. We'll see how true that is... I've tried before and always seem to get roped into looking after the kids instead...
Thanks! Yeah the turbo hoses are a pain but so much nicer to look at than the crappy hard lines. Definitely a job I'm glad I did out of the car, props to you for doing it in the car!
My shed is my palace, I love it! It's a bloody mess cause I'm a bit of a hoarder but it's so much better than working in a garage where it all started.
you might have to tie it in a knot for a few years and wait for the young ones to grow a bit so you can get the serious stuff done in the shed, lol
Understand your frustration but at least it is under your control, when there is a builder in control and BS ing to you, it seems worse :(
But mate, it is going to be one of the great builds . Busting to see yours and Paul's on the road again.
I know I do not know much about mods but I believe mine turned out OK in the end and exactly what I was after :1311_thumbsup_tone2:
I've already got the doc to whack a knot in it a few months ago so I can run around the paddock without any mishaps!
You definitely had a bad trot mate but at least you had someone to blame. When mine f**ks up I've got no one to blame but myself! 100% accountability!
Mine is far from a great build mate but hopefully showing some the basic stuff I'm doing (which no doubt bores the more advanced readers) helps motivate people to have a go at it themselves.  It's amazing what can be achieved by just having a crack!  Start on small stuff and grow as your skills and importantly confidence improve.
    • Thanks for the replies guys, I'm new to the world of hybrids. It's definitely a lot cheaper to run than my old m35 stagea that's for sure but yeah well shy of the claimed figures so far, hoping the batteries not poked (although it came with a 3 year warranty for the hybrid battery as well). Wondering if it'll take another tank for the ecu to figure out the higher octane if it's been run on 91 for a bit?
    • welcome to SAU  sounds like you do have a bit of sorting out to do on the car, but it looks nice you can attach pics directly after you've made 10 posts.
    • yeah a coolant pressure test will tell you if you have a leak anywhere as it just pressurises the system. If it drops from where you set it, say 1 bar, you have a leak somewhere
    • Thanks heaps. So basically, bare block, very very similar. And cranks are the same
    • Hey guys, I have dipped my toes into the pool of skylines finally and figured I would get amongst the forums and make an introduction post! My name is Callum, I'm from the north side of Sydney, and I am now 6 months into owning my 1992 R32 GTS-T (already having half of that time off the road in true nissan fashion). It is originally an AH3 car but at some stage of its life it has been resprayed in and out in TH1 with (in the sellers words) extra purple, parked next to an actual TH1 car it is a fair bit lighter in colour. It has also had the original RB20 swapped out for an RB25DET NEO which I presume to be out of a Stagea going off the AWD sump that has been sealed up. I won't go super into detail with mods as I want to create a build thread post soon. Unfortunately the car seems to have had a hard life as many of these have being previously a cheap sub 10k car, and I have barely any history on it so if anyone happens to recognise the car or thinks they may have any history I would LOVE to hear it as I am a bit of a nerd when it comes to car history, the seller had it roughly since 2020 I believe and was from Parramatta area if that helps. Look forward to being a part of the community, I have been to 2 SAUNSW events already (one being in 2022 prior to ownership, and once more a few weekends ago) so you could say I am not brand new to it but can definitely be more involved via the forums! (side note: I am pretty new to forums and struggled to attach pictures of the car, is there an easier method than having to have the pictures on facebook and copying the link from there? would love to know for future reference cheers!)
