Finished off the transfer case today (finally...). Ended up stripping my spare transfer case to use the housing as the broken chain had almost completely chewed through the housing. It can't be far off going right through.
New housing -
Stuffed housing (you can see the groove  which is 3 or 4 mm deep)-
Comparison -
Set-up the discs in the alternating driven/friction pattern. With a bit of trial and error (luckily had 3 sets of clutch packs to choose from) managed to get the right clearance once assembled. Was a bit of a mission but with the right tools and some patience it's a job that someone with slightly above average mechanical skills could have a crack at.
Some progress and final product shots -
Now back to the wiring....
Faaark!
  • Like 2
Had a bit of a play around with mounting the Haltech coils today. Not sure if this is the way it'll end up but it should do for now!  Couldn't decide on the direction to face the coils so ended up going with symmetry! There were only certain ways they could face so they didn't hit anything so it'll have to do for now until a better option comes up.
  • Like 3
Extremely nice build with little restorations here and there! And the shed is awesome, I can imagine how nice it is to have your own time-out in there.
About the manifold, it's almost like mine, except I have it on the RB25. Just be careful when fiddling around with injectors. Had some E85 pissing all over the manifold runners from cracked injector o-ring. Needles to say, paint peeled off like candy paper..
Keep up the awesome work, looking forward seeing updates on this build!
  • Like 1
Thanks for the kind words!  Your engine bay looks very nice!  Very clean.
I always use heaps of rubber grease when I'm installing o-rings or seals so hopefully no fuel leaks for me!
Not a lot of visual progress, it's like the last month of building a new house, it's when a lot of the fiddly stuff gets done but it's hard to see any sign of it!
Still fiddling with wiring and mounting all of the new sensors.
Also playing with an affordable alternator option (Nissan Maxima 120amp) will post details once sorted. Alternator was only $95 so hopefully it all works!
Pretty new BOV hoses-
Gave my headlights a run on the buff, need more of a sanding to get rid of ultra fine cracks but the improvement is incredible!
Tipped over the engine and poured as much oil into the oil pump and inner oil galleries as possible to help with initial start-up and priming oil system.
I should have popped the champers at this point as this is the first time in about 3 1/2 years that the engine has been off the engine stand!!! Seemed like a significant moment!
Dog was thrilled...
God it's a shame to hide these things, such a work of art!
Obviously put in a new spigot bush while I was at it.
Feels like progress!
On a side note the shed is getting a little more comfortable every day, now have the footy and Netflix,  I think my wife is getting nervous I could be moving out here soon...
Shit the bench is a brothel.
  • Like 5
Engine and transmission now mounted to the k-frame, the string hanging from above is to align the k-frame to the car so hopefully the car drops directly in line with the engine-
Transfer going on-
  • Like 1
Sorted out the alternator today.  It's just a 120 amp Maxima alternator.  $95 delivered off Ebay so a cheap option!  As a tensioner I used a spare (RB26) power steering tensioner and just chopped it up a bit and drilled an extra hole.  It's not show car worthy but quick and easy.  Once I paint it up it will look a bit nicer-
And after an amazingly long time, she's home!  Albeit temporarily while I finish off the wiring.  It will need to go in an out a few more times to get everything right.
  • Like 7
One word - Faaaaaark!!!
It hits very solidly so it's in the way by a fair whack. The engine still needs to come up a bit which will make the problem worse!
It looks like I have 2 options,  try to find a shorter master cylinder or delete the booster. Preference is for option 1 but firstly finding one that is small enough to fit and secondly one that will seal the booster (to hold in the vacuum) is going to be a challenge. I've ordered what appears to be a smaller master but we'll see what happens when it rocks up. The lugs are in different places to the standard master so it's not a straight forward solution at all!  Its looking like strong clutch leg is forthcoming!
Have a look at the Gtst stuff, they don't have a booster.
my OS twin plate is not overly heavy on the pedal, but I'm not sure if they have a different leverage ratio on the pedal assy.
I can take some measurements if you need of the pedal box, it might be a straight swap if they are different.
cheers
Thanks Luke.  Maybe if you could measure the length of the master cylinder itself.  The GTS-T booster will be a bit better as it exits underneath not to the side.  I think it would have to be shorter than the GT-R master as well (which I don't think it is) as the outlet location.  I'm pretty sure mine is about 80mm long for reference.
If I have to live with out boosted clutch I'm sure it will be fine.  Especially with a Nismo Coppermix which are famous for being so light.
Cheers.
Ha ha "plebs"!  Yeah I'm trying the cheap option first (master), if that fails then delete booster is the way.  I need to do more squats anyway to buff up my pigeon legs!
When the car was still on the road (bloody years ago!) I drove it to work one day when it must have been a full moon the night before.  There were about 3 crashes and 4 breakdowns along the Westgate Freeway and through the tunnels.  It took over 2 1/2 hours to get to work (27kms).  The clutch I had then was a bloody heavy single plate so by the time I got to work my left leg was so f#$%ed I could barely walk when I got out!  It was the worst trip to work in my life.  I never drove it to work ever again!
Now that I'm in the country my trip to work is 10 minutes regardless of traffic so if I do ever drive it to work I'll need to leave home 20 minutes early and head out into the country a bit just to warm it up properly.
Hi mate,
i just had a measure up, the master cylinder is about 80mm in length.
Its 5/8 in diameter and the hose exits straight under the cylinder.
i took a couple of pics if you pm your number I can txt you them.
Cheers
Hopefully this tiny little sucker will do the trick.  It's under 70mm long so heaps shorter than the standard master plus the location of the outlet being further forward hopefully should be a winner.  Only dramas will be the outside bore size (to fit inside the booster), sealing it to hold vacuum and lastly the fact that the mounting tabs are in different locations.  Apart form that perfect!!
  • Like 1
  • 1 month later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
