The guy in the video is an idiot and should read a manual before uploading shit like this. That collar is the main thing holding the shafts from coming out, it must be removed first, and hence why a factory part was available for removing it. He is trying to press though the counter shaft collar ! ? Once that counter shaft collar is off you should be able to tap both shafts out of the bearings fairly easily, firmly but nothing like requiring a press. The fit on the bearing is nothing like the collar - that is really difficult to get off, hence why you need something fairly chunky to securely pull against.
Notice how he said the main shaft pressed easily and that the counter shaft is really hard ? Geez, I wonder why ? He was only pressing the main shaft away from the bearing. Then he's trying to press the counter shaft through the collar and bearing. ?‍♂️
Surprised he didn't snap the standard cast centre plate in half doing that, what a Muppet
Continuing the DIY theme on this car, my next job will be to make up my own puller for the bush that has Ben all worked up ?.
It's not going to be a fancy looking billet round  bit of kit like Ben had made up but hopefully it should do the job.  Below is what 2 minutes in excel does to give a visual interpretation of what it may or may not look like!  I'll pretty much just make it up as I go so will no doubt change.
What I can't show the in the picture is a lip that I will weld onto the top which is what the puller will grab onto and pull from.
The square bits on the outside are nuts that will be welded onto the add strength to the bolts and I'll tap the thread right through the nut into the edges of the metal plate it will be made from.  Only the very tip of the bolt will be machined down to the small enough size to go into the little holes in the bush.
Really wish I had a lathe for things like this.  I'll probably just put the bolts in the pedestal drill and turn the bolts down that way.
As with most things I've done it will be trial and error but I have the concept in my head ready to go!
I'm up the hills camping and dirt biking so probably won't get to it until next week at soonest.
Wish me luck!
  • Like 1
Nah, not worked up, just that vid almost sent you on a mission stuffing around trying to use a press. I like how he actually didn't show the whole process of completely pressing the shafts out. Like he finished doing it and went, 'um this collar thingy is separate ?"
I'm not sure what you've proposed will work. It might, but that collar is really tight. I won't sell my one as will always need it, used it quite a few times, but do you want me to express post mine down to you to use it and maybe copy it ? You can post it back to me when you're done.
Ok so Project "Waste More Time" is underway...
Got the high tensile bolts for the puller today. Don't have a lathe so whipped out the poor man's version ?.
Never tried it before but seems to do the trick! I kept the verniers handy to monitor the size as i went and then finished them off with a flat file to get as close to the 5mm hole size in the sleeve as possible.
Once I've made the puller section I'll grind the tips to the perfect length (3.85mm) so the necked down section is as short as it can be to make it as strong as possible.
Feel free to let me know if posting this stuff is boring as bat shit. Its not very car related at the moment. I've got thick skin so you won't offend me!
  • Like 3
Looks like your making progress on the collar tool. Since the old man's GTR is in the middle of it's rebuild, we thought why not check the box out and modify the transfer case, which will be getting the 10 plate mod. We're doing the old man's box at the moment now, a no rush inspection, but if you have any questions will be happy to help, as now will be the perfect time to take pics and explain anything while we're doing it at the same time. We will be getting that collar off soon as you can see so I'll try and post it up getting it off, and the process of main and counter shaft getting removed. Notice how thrilled he is to be helping with yet another GTR box....at least this time I'm helping with his bloody box !
Thanks for your offers @BK.  Your dad looks thrilled!
Tool is coming along. Made up a plastic mock up to start with.
I'll let the pictures do the talking for the rest!
Hopefully finish it off tomorrow and test it out!
  • Like 2
Finished off the puller. It certainly didn't end up pretty but its super strong.
And the results? Failure!
Unfortunately even though the bolts are 13.9 high tensile the still sheared off.
I've cut off the 8mm nuts off and I'll drill them out bigger so I can up them to 10mm. I thought the 8mm would be strong enough but no...  I'm hoping the bigger bolts will be harder even though the size will still be 5mm.
I think I might get them properly necked down on a lathe as my method is weakening them.
If that fails I give up! ?
  • Like 1
Why not weld more shit on to your  puller and use decent material at the correct diameter that the bolts then hold in? No turning required, like some silver steel the correct daimeter or chop up some drill bits and use the shanks portion.
Don't go using a lathe now! You have come too far!
  • Like 2
Hmmmm, I like the concept!  I might have a quick crack at that before going the bigger bolt option. Might be too late now that I’ve already cut/ground off the 8mm nuts.  If I can’t resurrect it from here then I’ll have no choice but to go the bigger bolt option. You triggered some ideas in my dull brain but we’ll see if they go anywhere. Cheers for the inspiration! ?
Ok so I know those bushes are tight but f♡ck me mine was tight!  So it sheared off two lots of my studs, snapped the tip off a puller arm, ripped off one of the 8mm thick metal chunks I welded to it to pull off and then finally snapped off an 8mm stud in my bearing puller.  There's no way that was normal tight!
I didn't take many photos as I was too busy welding, pulling, braking shit, grinding and swearing my arse off to stop and take photos!
In the end I just went f♡ck it and cut the f♡cker off as the counter shaft is bin worthy only anyway.
Man what a bloody mission that was!  Be interesting to see how difficult the one in my other box that is donating the counter shaft is.  Hopefully I don't have to cut that one off...
Right @BK what's the next step in the no press dismantle process? Does it involve a piece of wood and some heavy down force?
Anyone got a cheap no crunch gearbox i can just check in....?
52 minutes ago, BK said:
You did use a rattle gun on your puller right ?
No, I used hydraulic pullers. The strain on them was insane! Theres no way the 3 pins would stand up to that amount of strain.
Can't do that, you're slowly loading everything up, hence why you're breaking shit. Rattle gun is the only way. You need that one quick burst shock to initially crack the collar. Once that is done, short bursts of the rattle gun until it's off. Remember you have to heat that collar up and expand it to get it back on, so it's always going to be on there stupid tight.
My collar tool has held up doing them all this way, using a 2 jaw puller on the collar sleeve tool. Never broken or replaced the high tensile bolts ever.
I think really just comes down to the inadequate design of the collar puller tool not exerting all of the force purely into the collar you are removing. My one has a perfectly neat fit on shaft, no slop, and is made out of pretty heavy duty steel. All force is transferred directly only into collar. Your setup was obviously straining the bolts too much.
That sucks man because you have to get the collar off the other one and reuse it still.
Awesome ! That's just the collar for $45 right ? What's main shaft 3rd gear set you back, about $150 - $200ish ?
Tapped them shafts out yet ? If you haven't, just put it on something like this, shafts facing down, and just alternate tap each shaft. Should come right out. SHOULD....
  • Like 1
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
