  • 3 months later...
Celebrate the small wins.....
Finally finished off my transmission dolly today about 6 months after starting it..
Would love to think that this led to further advances but unlikely at this point. Still deep in dirtbike "season" so probably won't get much done again till September or thereabouts.
Hope everyone else is getting shit done unlike me! 🤙🤙
  • Like 2
Your crazy ! Motocross after 40 - yeah / nah. I'd hate to have a bike injury at this age ! My broken arms and shoulder still give me shit.
Sort of getting things done. Just come off covid so that kinda stuffed everything up. I like the setup above, very cool. I still use adapter brackets on a floor jack for the box work, so will try and get the white 32s box in today.
It's actually worse than motocross,  it's hard enduro so brutal on the body. Did a 4 hour race last weekend,  cooked me!
Glad you're getting into yours. I really want to but time (and laziness) are working against me.
After having my gearbox back for about 12 months after getting the gearset put in it, its finally back together apart from the front cover which I've ordered a new gasket for.
Decided to stick with my modified transfer case as opposed to the Race Pace modified one I picked up with a busted gearbox I bought. Hopefully I did it right all those years ago and doesn't come back to haunt me! 🤣
Not much progress to speak of but yet again, the small wins determine the success of the larger battle...
  • Like 4
Finished off the transmission front plate, fit the clutch and got the transmission bolted up to the engine.
Decided to use a roller spigot bearing this time, anyone had any success/failure history with them?  Makes sense to use one to me...
I love seeing it like this. Almost starts to feel like it may actually get back in the car at some point!
  • Like 3
Roller spigot, I don't trust them. I use them in the XR6 because that's what they are factory, but in the Nissans I've thought about it, but thought it's  completely pointless in the end. I just stick to the good old genuine sintered ones that never give any trouble.
I hate to pull a box out just for that if it comes apart. Just a don't fix what's not broken kind of thing really.
It might give me a reason to pull it out again for the 5th time....  Because that's what I want...
  • Haha 2
Had a quick play over the weekend.  Finished off a few small jobs on the engine (fit the oil baffles and splash guards into the valve covers, fit starter motor, alternator, etc) before it's ready to go back into the engine bay.  Onto re-wiring the whole shit-show again soon, oh joy.....
Also had a bit of a play with firewall insulation.  Very hard to gather anything from the pic below as it looks completyely shit but hoping to use it to neaten the firewall but also to hide the brake hoses behind it as well.  I was going to completely re-route the hoses but if I can hide them behind the head shield and still look nice then I'll go that way.  I think I'll still re-route the brake lines to some degree.  Will probably use flexible braided hose just to allow a bit more flexibility moving the hoses around.  I'm thinking I may hide the wiring loom behind the shielding too for heat protection and for neatness.
Once I get the brake pipes out of the way and trim the shielding around the trans tunnel it will look a lot neater.  I think I will probably powdercoat the shielding black if I end up using it.  The sheeting from Car Builders website is really easy to work with.  will probably use it in other places too.
No description available.
  • Like 3
Ordered all the fittings and hoses to make up custom PVC coated, braided brake lines.
Still tossing up where I run it all.  Options are behind the heat shield as per my last post or seeing I'm going full custom now I may run the right front and the rear line across the k-frame under the engine instead of across the firewall where they currently run.  This will reduce the lines across the firewall to just 2.  I'll possibly then drop the lines down lower under the crease/join that they normally run above.  Then I can drop the heat shielding lower too so it doesn't have to sit as high and should look neater.  Is it a waste of time and money?  Yep but I'm determined to do it!
This is all going to be a bit of an experiment as I'm going to TRY to convert the fittings on the master and ABS module from M10 flares to banjos.  May mean I have to machine a tiny bit off each of the outlet/inlet points on the ABS module and the master cylinder to create a sealing face for the banjo washers but it should work.  If it was easy it would be boring....
Image 1 - Stainless Steel Banjo Bolt AN3 AN-3 3AN To 10.2mm (3/8") Fitting Hose End
Went with black for the PVC coating so should hopefully look nice-
AN-3 Stainless Steel Braided Brake Lines (PTFE) - Carbon - Track Formula
Wish me luck, it could get ugly.....
  • Like 1
Decisions were made and regrets were had today.
No turning back from here, looks like the engine bay IS getting painted. I've procrastinated that many times over this but finally decided to do it after all.
God I hope I can make it back from here!  And I thought I was in deep before! 🤣
A bit nervous as I've never done any real body work or painting before.  Surely nothing can go wrong......
  • Like 5
Put up a whiteboard so I could keep track of where I'm at. Kicked things off with some inspirational words. Seemed to have worked!
Got absolutely everything out of the bay today. Ain't no turning back from here!
Not going to go crazy in terms of filling holes or smoothing everything off.  Just going to clean up all of the (horrible) factory seam sealer and reapply it neatly.
Trim it all up like this and then transition everything nicely.
Waiting on a set of heavy duty 1000kg casters so i can make up a dolly to be able to roll the car outside when I'm sanding.  I refuse to completely destroy my shed cleanliness with body filler dust!  Unsure as to whether I'll paint it on the hoist or outside on the concrete pad.  I'll make up my mind when I'm ready to paint. Obviously advantages to both. Would make painting under the chassis rails and getting inside the engine bay a hell of a lot easier doing it on the hoist so will likely go that way.
I barely slept last night, all I could think about was stripping it all down and painting. Bit sad really 🤣🤣 but I'm excited to see it sparkly white!
  • Like 3
On 22/08/2022 at 8:45 PM, Dose Pipe Sutututu said:
Fark it, tube front end. Might as well 🥲
Yeah you're right, I may as well! If it was chock full of rust I probably would.  Very happy with how little rust there is actually.  Just a couple of the bolt holes where the alloy guards bolt to the body have a touch of surface rust, everywhere else is perfect.
Ordered a new spray gun yesterday.  Read a few reviews and watched a few Youtube vids and even though it's a pretty cheap gun even some well regarded painters rated it as a good beginner gun.
DeVilbiss FLG-5 – Spray and All
It's a Devilbiss FLG-5.  Hopefully when  they were referring to "beginners" they meant absolute retards.  Should be fine if so!
Will most likely practice a bit of painting on a spare bonnet I have or just pinch some transit damaged panels from work that just get chucked in scrap metal.  Looking forward to learning a bit of the art of proper spray painting.  I'm a highly advanced guru of the rattle can but aren't we all! 🤣
Hopefully my dolly wheels arrive soon so I can get cracking while the motivation juices are still flowing strong!  They have a tendency of running dry if I'm held up for too long.
  • Like 1
Shoota's workshop tool construction post # 57.....
Got a start on my front dolly last night (until I ran out of MIG gas....).
301231016_739205860474400_6813256023735326446_n.thumb.jpg.d26e62367c016302caf4bcd9753bec60.jpg
300620793_3196887327291815_2979642277147312755_n.thumb.jpg.494ca7aac09ad73317357ca902d65654.jpg
301599994_391582066457689_1627640926689162518_n.thumb.jpg.a8ddd4a4a2ca56cc5dae23c7c6ae87c5.jpg
300657802_1172141066985632_6848970269674908476_n.thumb.jpg.3b2267ed01411316dc8078d8a93ed549.jpg
Getting more gas after work today then hopefully by tonight I can get it finished off and rolled out of the shed for a wash for the first time in I can only guess at 5 or 6 years.....  It looks like it to.  If I'd died people would have stumbled over this thing thinking it was the best find in 10 years....  There are rat foot prints up over the roof...
I found some munted rims at work to put it on to roll it out (don't wanna scratch or get paint on the Advans....) and as an upside I'm pretty sure I now have V-tec.  Yo.
300514553_2812369665724817_5627852928304260958_n.thumb.jpg.7a25118494a62840b227fe765bd55af4.jpg
  • Like 2
Ok, I admit it...  Tool version 1, massive fail.  Right from the start I was going to have it on legs but in the excitement of getting it finished I completely dodged that step of the (unwritten) plans...
Couldn't even get the dolly caster wheels to the ground when I lowered it down...
Version 1-
Back to the drawing board...
Version 2 (code name lanky legs)-
Quick lick of paint and she's good to go-
Once the paint dries I'll get it mounted up and drop her on the floor.  Hopefully my welds hold....
I probably should triangulate the bottom corners but it should be fine. With nothing in the engine bay it's probably a few hundred kgs lighter than normal.
  • Like 2
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
