Ok, I haven't posted for a while as I was having trouble embedding photos.
I've had some ups and downs of late.  I was nearly ready to bolt the k frame to the car when I discovered my sump adapter blocked the rear dipstick hole....
So engine out, sump off and I drilled out the bush that blocks the front dipstick hole.  I made a little adapter to lock the dipstick in as it was a bit loose.
So repeated the whole process again and finally bolted it back into the car-
I ended up getting a clutch booster delete from Garage 101.  Very nice piece of billet aluminium that brings the clutch master back a fair way-
It's still EXTREMELY close to hitting my inlet but it should be ok!  If I decide to try to engineer it I might be in trouble though (10mm rule)-
So as of today I've mounted the ECU and run the wiring into the cabin, I'm now in the process of running the wiring through the engine bay and terminating it at the sensors/connectors.
In some ways I'm so close and yet I'm still so far away from completion!
  • Like 2
Wiring-
I bought myself an el cheapo Ching Long Lie AC/DC TIG welder so I can do some stainless and alloy wleding.  I've had a bit of a practice to start to get the hang of how it works.  It's a lot harder than MIG welding but I think I'll get the hang of it after a bit (ie a shitload!) more practice.  Just getting the hang of heat control at the moment-
  • Like 2
ECU-
Now E don't CU-
"She's all factory ociffer......" cue drunken slur.
I decided to mount the ECU now and properly or it'll end up banging around on the floor for all time. Fits nicely behind the kick panel. To be honest I wasn't expecting it to!
Are you able to do me a favour and measure the length of the whole clutch master assembly? Trying to work out if it will work with my Plazmaman plenum and 30 block in a 34.
Appreciate it!
Appreciate it!
No probs Brett, I'll do it tonight and come back to you.
  • Like 1
59 minutes ago, reaper said:
I am sure it was! Really appreciate it though thank you very much.
Too easy.
Pretty much finished off wiring up the top of the engine last night-
Just MAP sensor, cam and crank triggers to do from the top then the fiddly crap under the intake manifold is next.  Fitting the wideband oxy sensors to the front pipes will be fun too....  At least now having the TIG I can weld on the bungs myself once I get a bit more practice.
  • Like 2
On 10 October 2016 at 11:38 PM, infamous_t said:
LOL looks like Danny @ 101 copied the booster delete @Sub Boy32 made for me when he installed it all those years ago.
[Cough] Ripoff [Cough]
However mine uses a different Nissan clutch master that fits better and has more room away from a large plenum like the Greddy one.
Edited by Sub Boy32
  • Like 1
Missed opportunity maybe?  You might have sold a few by now if it was a few years ago!
1 hour ago, Coullsy said:
I laughed a little harder at this than i probably should of.
love the workshop
I'm glad at least one person got something out of it!
Yeah I'm pretty fortunate to have such a good shed and a great wife that doesn't ask "Where did that come from?" or "How much did that cost?" every time she comes in the shed!
Thankfully she doesn't visit too often.....
  • Like 1
Not missed, sold about 30 of them all over the world......
http://www.gtr.co.uk/forum/154737-sub-boys-r32-gt-r-then-now-9.html
Edited by Sub Boy32
I looked everywhere for one (apart from a UK Skyline site obviously!) but could only find the one I bought. Credit goes to you for the concept then, thanks for designing it!
Haha! No dramas
On 10/14/2016 at 7:51 PM, Sub Boy32 said:
Haha! No dramas
Are you still selling them? I'm trying to fit a Plazmaman plenum and 30 bottom end into my 34 gtr and I am worried the Garage 101 setup still won't clear...
Yes I'm still selling them,
 flick me and email if you like
[email protected]
Chris.
  • Like 1
Wiring is almost finished.  Just need to wire direct power to the ECU (using the wiring harness to connect directly to the battery as opposed to patching into the car.  Just reduces the likelihood of any issues and makes chasing power issues easier too) and wire in the AEM ignition module.
Mounted the pressure reg and ethanol sensor and made up hoses to suit.  I'm also running a fuel pressure sensor as well so I can use that as a failsafe to cut power if I lose pressure for any reason-
http://DSC_7932.jpg
http://DSC_7934.jpg
http://DSC_7936.jpg
  • Like 3
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
