Hey all,
Im chasing some 26/gtr inlet bits for my 26/30 project. I need pretty much everything (sensors/aac all that crap) on the inlet side bar the plenum. Also need a cas and an injector resistor pack and the metal thing that has timing marks on it. I also need water and oil lines but im pretty sure Kat has soome from memory.
Cheers
https://www.sau.com.au/forums/topic/414823-anyone-got-some-26gtr-inlet-bits/
injector resistor pack - Got a new one $100
Haltech does it for me :)
May have water and oil lines. I know I have a full new kit of hoses.
also have a full new set of ID1000cc injectors if you need em down the track
Sounds good Richard. Let me know about the hoses and ill take the resistor pack. Thanks for the offer of the injectors, but ill be going either 1500s or 2000s in the gtr so ill put the 720s in this motor (its for a vl i bought as a tow car lol)
^ This guy Andrew is awesome ^ got heaps of parts off him.
Cheaper, faster delivery, nicer :thumbsup:
Ah ok cool, might see what its all worth then.
Let me know when i can meet up with you and grab that injector pack. Im free mon,tues and thurs.
my numbers Zero 404 102 21 five. Just send me a txt :)
Full set of new hoses for an RB26 engine but not oil/water lines for Turbo/s.
Also new seperate set of heater hoses only - with clamps !
What about a near new after market steering wheel with Boss kit for GTR
Intercooler mesh huh ?
New quality upper control arms even
Power steering pump maybe tempt you :D
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
