Hi guys,
Sorry if ive posted in the wrong place as im new here, Ive just brought 1996 skyline Hr33 Gts-t that im going to be drifting, as im pretty new to this i just thought i'd ask some questions. Ive been told it has a Garret to4e turbo firstly is this a good turbo???, hsd coilovers,varex remote control exhaust system,,big front mount intercoller,wastegate,19inch lenso deep dish rims,shimmed diff,extended camber arms. Now it has standard maxed out injectors and its pushing over 300hp but with new injectors and a tune up it should improve significantly. So that brings me to another question what size injectors are standard and what should i buy ( keeping in mind im not overly cashed up ) and any other easy cheap mods i can do at the moment thanks for your help guys..
https://www.sau.com.au/forums/topic/414827-1996-skyline-hr33-gts-t/
firstly, there is no such thing as a HR33 gtst, they are ECR33. HR33 is a gts running the rb20E, so if yours has HR33 in the VIN then it isn't actually a gtst, so it won't have some of the better gear that the gtst got (better brakes, etc) unless they have been fitted by a previous owner.
but enough of me being picky.
the stock injectors are 370cc. you should look at getting at least 550cc injectors. if you want to d oit cheap, you could get some second hand s15 injectors. they will fit in and are bigger than the stock injectors at 444cc or 480cc (can't remember which). this will obviously require a retune of sorts. sometimes you can simply alter the injector size in the settings (depends on the ecu), but it's always worth getting a proper tune done just to be on the safe side. what ecu is the car running?
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
