  • Replies 52
lol your bro rarely goes to school?
Yeah, they badass. Wagging 4 lyf, yo. (My y12 motto 1/4 of the time, anyway xD).
Nah, it's only really if I'm free and for some reason my mum or dad can't take them. Considering it's in the opposite direction to both work and uni, it's never "on the way" :P
Haha can't wait to get out there but I need to get myself and the car ready!
I haven't had a car for a year so i feel like i'm learning how to drive again!
What do I need to do to get my car ready for track? Some things I have seen;
  1. fire extinguisher
  2. helmet
  3. mark battery location somehow???
  4. new brake pads for track use so I dont get brake fade after 2 laps?
  5. Engine oil cooling improved?
Help me get her ready so I can beat your asses on the track :P
ALSO I need a tune BADLY, running rich and getting <300km per tank anyone got any info for me? on price/contacts tips? Car has Apexi Power FC
Edited by jukic.j
I have some little thing which gives me readings between like 12.0 and 17.0 (rough estimates cant really see it while driving) is that the thing that is supposed to be hooked up to the O2 sensor? It's also my turbo timer. I have an Apexi Power FC.
I was looking at getting a wideband is that the same and/or better than an O2 sensor?
The guy I bought it off said it needed a tune, how can I tell if it's the O2 sensor or it just needs a tune or is it a case of needing both? I'm super noob i'm just learning now.
Should have an inner eastern suburbs meet up. Balwyn maccas br0s lol.
Honestly not sure if there are any exact ways to tell, but the engine light I'd assume could light up. The only way i knew it was mine was I put two and two together. Personally I don't know a lot about wideband, but there are some threads on it I'm sure.
Edited by gtsttrk
  2. helmet
Cams licence, properly mounted fire extinguisher, helmet & stickers then off you go
As for tuners. Chequered is closing soon so Racepace, Chasers Eastside, Sabbadin Automotive all of which will look after you and give you a discount if you are a financially paid SAU VIC member
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
