  • Replies 52
How much does a tune usually cost? I have a friend who gets his R33 and evo tuned tuned by his friend, evo tuned to e85 aswell but wondering the downsides/risks of road tune vs workshop tune? I mean if this guy trusts his car with him he must be alright?
off topic what do I need to run e85?
http://www.facebook.com/groups/Driftsales/306731592759916/?ref=notif&notif_t=group_comment
Northcote and generally drop by monthly meets. Don't stress about track days, some minor things already discussed. Your first few times are more about getting you sorted than worrying about the car. I had full length cotton clothing helmet, extinguisher and borrowed some blue duct tape. Once hooked you'll have plenty of ideas on how to blow money.
Just bought a GS342 for the 33, mechanic calls today and there's a pump in there flowing basically double what the 342 would.
Y I always get dicked.
What are the specs on the pump I might be interested in buying, thinking of going over to E85.
I used to live just off Greythorn Rd... Now living in Footscray, but regularly back in the 3-1-0-4!
Cool might see you around.
I was asking more what do I need to do for my car not to fail on the track, for example I have been told that street brake pads will only last 2 laps and then be basically useless. Engine oil cooling was another. Do you guys get this or have prepared for that somehow?
I'm in Balwyn. Seen a black r33 with black recaros a couple of times on Whitehorse/balwyn roads. Was that you?
This is mine but diff driver and rims than that pic. Same rego.
Might wanna change to return type cooler piping, a hole cut for piping is a big no no on a series 2.
Nice car though :yes:
very clean car you got there mate.
If there are any meets/gatherings in balwyn or surrounding suburbs, let us know. keen to meet up.
Keen for that, haven't met anyone in the car scene since I got her so far.
Yeh I only figured that out after I had given deposit and signed contract to purchase. It's on the list of things to do but not at the top.
Should do an eastern suburbs meet, Balwyn and surrounding suburbs!
Out of curiosity, with a non return flow can the car technically ever be returned to RW condition? Or if you got dicked would you have to gain a engineers cert?
I bought it with rego and to buy with rego you must provide a RWC as part of the sale, so yes it was deemed roadworthy condition.
Defs keen for any kind of meet.
In other news... got my first EPA letter... damn that was fast. FML
Exhaust noise. Now to figure out what to do about this.
Edited by jukic.j
"Either excessively noisy or to have had a faulty exhaust system"
My car is noisy but nowhere neat the volume of a Harley davidson for example. Seems like my first dose of police targeting Skyline drivers.
Edited by jukic.j
That sucks, do you have the standard exhaust still? Makes me a bit nervous, just replaced the exhaust with a straight through pipe from the cat back and mine is VERY loud. Police presence isn't to bad around our area though, apart from the odd HP down Burke road (and It's not driven a lot on weekdays).
But yeah, there's a major police presence at the moment this year. Hopefully you can get it cleared up ASAP mate.
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
